04-06-2016
20:14
20:15
04-06-2016
20:14
20:15
04-07-2016
08:57
08:32
04-07-2016
08:57
08:32
@Tracylo Welcome to the Fitbit Community! I recommend to perform a restart on your tracker first. Also, make sure you are not wearing it too tight as that may interfere with the signal. Use the tracker a little bit far up your wrist (like one or two fingers from your wrist bone on a regular day); blood flow is stronger there and you will get a better and more accurate reading. If you are doing exercise; it is recommended to use it 2 to 3 fingers from your wrist bone for improved heart rate accuracy.
Hope this helps! Let me know how it goes.
04-07-2016
08:57
08:32
04-07-2016
08:57
08:32
08-28-2016 13:25
08-28-2016 13:25
Hi SantilFitbit,
Restart hs been done and outcome was exactly as you described with v122 appearin on the screen, followed a little later by the message "Im READY".
Now to lift my heart rate up again. I'll advise the outcome.
Many thanks. Enjoy your day.
Lindsay S
08-29-2016
13:34
08:32
08-29-2016
13:34
08:32
@LindsayS Excellent! It should work properly now! Let me know the outcome! I'll be around! Also, check the Discussions Board as you will find a lot of interesting boards there. Feel free to post on any thread you want!
Keep me posted! ![]()
Best Answer05-10-2017 14:00
05-10-2017 14:00
The suggested fitbit placing on the wrist does not work in actual use as the fitbit goes down up to the wrist bone due to gravity unless perhaps it is put on very tight. I have tried the suggested fitbit positioning when cycling or brisk walking and it does not stay on place as recommended.
05-10-2017 14:08
05-10-2017 14:08
11:09
08:33
05-11-2017
11:09
08:33
@Bignay Welcome to the Fitbit family! It shouldn't be a problem if your Fitbit moves up and down between your arm and wrist bone. It should be fine as blood flow on that part of your arm is stronger so you should get the readings even if its loose. Are you getting the readings?
@LindsayS Thanks for sharing your experience!
Best Answer12-10-2017 16:22
12-10-2017 16:22
Hello Santi
if worn too loosely it eventually will travel to the underside of the wrist. Can it read here too?
Best Answer12-10-2017 18:33
12-10-2017 18:33
12-11-2017
09:41
08:55
12-11-2017
09:41
08:55
@adam7272 Welcome to the Fitbit family! Yes, it should work properly there as well. Just make sure it is not too loose and not too tight. Try to find the point that's two to three fingers from your wrist bone. But yes, it should work properly just like @LindsayS said.
Try it out and let me know how it goes! ![]()
Best Answer12-16-2017 16:55
12-16-2017 16:55
I have a similar problem with my ionic in the water. My Fitbit will pause while doing water aerobics. I have not intentionally paused it. Any suggestions?
Best Answer12-17-2017 01:04
12-17-2017 01:04
Best Answer12-17-2017 05:38
12-17-2017 05:38
Best Answer12-17-2017 15:03
12-17-2017 15:03
09:22
05:40
SantiR
01-31-2018
09:22
05:40
SantiR
I’ve done every fix you suggest. I had owned 3 Charge 2’s and all have performed exactly the same way — not good or worthy of a HR monitor to track during a workout for people who sweat.
My third Charge 2 currently loses half the band when I remove it (???). Why on earth do they think you might want to change colors of the band? I guess it is a way to bleed more dollars out of us. The band doesn’t stay together —- now I need to purchase another band to replace one that was designed to be replaceable (for esthetics) . . . I must replace it because their bright “design” idea busted!
Moderator Edit: Format
Best Answer01-31-2018 11:27
01-31-2018 11:27
01-31-2018 11:50
01-31-2018 11:50
Best Answer01-31-2018 11:50
01-31-2018 11:50
Why? What's the matter with their engineering? I have had numerous Fitbit's of different styles. Each and every one of them has had a major flaw.
02-24-2018 06:04
02-24-2018 06:04
I try all the pulse corrective actions, results improved slightly but not satisfactory. I expected more from this device. All the statistics created are suspect. I’m sure all the calculations are within tolerance but we are left with a GIGO condition: Garbage In – Garbage Out
02-24-2018 07:17
02-24-2018 07:17
