10-03-2018
07:12
15:47
10-03-2018
07:12
15:47
I just read through the entire Charge 3 Manual and there is no section in there on clock faces. Does the charge 3 have more than just one clock face? If it has different faces, does anyone know what they are? I was surprised there was not section in the manual on changing clock faces. Thanks
Moderator Edit: Updated Subject for Clarity
The clock faces no longer appears on my dashboard (since the last update) so I cannot change the time display. How do I get the Clock Faces back to my laptop's dashboard?
Best AnswerThanks, I finally found the clock faces on my Android phone app and was able to adjust there.
Best AnswerI have a charge 3, and there’s only one digital clock face available. What am I doing wrong?
Best AnswerHello, I tried changing my clock face on the Charge 3 a few weeks ago but somewhere down the line it never finished completing the download and I've had a clock error on the screen since that day, it says goto the fitbit app and try another clock. When go to the app and try to go choose another clock face it doesnt allow me to. Has anyone found a workaround for this?
Best AnswerWhat do you do if there is no "Change Clockface" button on that screen. It only shows the Analog stat face which I'm using now. Below that name is Fitbit and Selected, but neither are tappable.
Any advice?
Best AnswerWhenever I try to download any of the clock faces it says that it is unable to download them on my device
Best AnswerWhenever I try to download any of the clock faces it says that it is unable to download them on my device .my device is an android device
Best AnswerWhenever I try to download a clock face it says that it is unable to download them on my device .my device is an android device
Best AnswerTHANK YOU! This was driving me nuts!!
Best AnswerMy Fitbit vibrated, then changed my clock face. When I went to Settings, the Clock Faces option was no longer there. I have changed my clock face before, so I knew how to do it. Thanks Fitbit for randomly changing things to not this user’s benefit 🙁
Best AnswerThanks! That did it.
