10-03-2018
07:12
15:47
10-03-2018
07:12
15:47
I just read through the entire Charge 3 Manual and there is no section in there on clock faces. Does the charge 3 have more than just one clock face? If it has different faces, does anyone know what they are? I was surprised there was not section in the manual on changing clock faces. Thanks
Moderator Edit: Updated Subject for Clarity
07-28-2019 04:32
07-28-2019 04:32
Same happening here. Please someone tell me how to change the clock face with the new update please.
07-28-2019 07:05
07-28-2019 07:05
FINALLY! Thank you!
07-29-2019 17:08
07-29-2019 17:08
It is a design fail if you an expert to tell you how to change the clock face and the 'accepted solution' not corresponding to what many people see when they open the app. I, too, cannot see the fitbit icon at the top of the open app on my phone. Really unsatisfactory that i have to waste time to work this out. This should be easy.
07-29-2019 17:24
07-29-2019 17:24
This is a design fail if you need an expert to tell you how to change the clock face.
For those who can't see the Charge 3 icon when you open the fitbit app on your phone, you have to be in your account view. You get to account view by pressing your ID icon on the top left of the screen (the round icon will be blank if you havn't added your own photo). Then under the section for Devices you press the Charge 3 icon. The rest is straightforward.
09-21-2019 13:47
09-21-2019 13:47
I keep being taken to the app store. I can click on click faces, but they all seem to be for other fitbit watches rather than the charge 3.
Where do I find some basic clock faces similar to those in the charge 2?
09-29-2019 06:44
09-29-2019 06:44
I have no clock face icon now on charge 3 app and no clock etc showing on my device. This happened yesterday and I’ve tried everything to reboot to no avail
09-30-2019 18:03
09-30-2019 18:03
09-30-2019 18:06
09-30-2019 18:06
I just took it back to the store and they gave me a new one.
10-23-2019 07:43
10-23-2019 07:43
This piece of CRAP ugly watch will no longer sync, or even present to pair as a blutooth device one of the forums says change the clock face to fix that.... The app/ phone won't connect to to fitbit I need to change the face from the watch. Your millennial software engineers need to get a job where they say "would you like fries with that"
12-07-2019 01:00
12-07-2019 01:00
This does not work. I have read page 19 of the manual and have tried it on both my Android phone and laptop. Like most manuals it makes assumptions.
Please give detailed instructions, with full explanations.
01-09-2020 02:25
01-09-2020 02:25
When I go to clocks it takes me to a commercial site on line for other models. I don't get any of those clock faces you show.
01-11-2020 12:32
01-11-2020 12:32
I am having a similar issue. When I go to select clock faces the progress wheel just spins continuously and nothing ever comes on screen. Using an iPhone X, all updates done today.
01-12-2020 20:35
01-12-2020 20:35
02-27-2020 13:57
02-27-2020 13:57
Hi, I'm trying to change my clock face on a charge 3, but I do not have the icon in the top right to change the settings. I have updated the Fitbit app and still no luck. Help please!
03-24-2020 10:58
03-24-2020 10:58
I just redown loaded the app haven’t used it in a while and paired it to my watch and still can’t get a watch face that’s for the charge 3 it’s for the versa and versa to and couple others none for charge 3 this Fitbit is just over a year old I’m so confused
03-24-2020 22:23
03-24-2020 22:23
04-13-2020 12:45
04-13-2020 12:45
I only see square clock faces like you'd expect for Versas.
04-13-2020 14:45
04-13-2020 14:45
04-13-2020 19:03
04-13-2020 19:03
How do I get anew clock face?
04-21-2020 04:04
04-21-2020 04:04
Hi
So i can select a new clock face but then it just never loads I clock on it the activity sphere shows for a few minutes before it times out and nothing changes.
How can I fix this?
