10-03-2018
07:12
15:47
10-03-2018
07:12
15:47
I just read through the entire Charge 3 Manual and there is no section in there on clock faces. Does the charge 3 have more than just one clock face? If it has different faces, does anyone know what they are? I was surprised there was not section in the manual on changing clock faces. Thanks
Moderator Edit: Updated Subject for Clarity
05-10-2020 06:47
05-10-2020 06:47
I have tried this and still not working. Please tell me what I am doing wrong
Best Answer05-10-2020 09:40
05-10-2020 09:40
Best Answer09-14-2020 19:19
09-14-2020 19:19
This appears to work if the Charge 3 is synched with an Android phone.
I use the App on my laptop -- no interest in using my phone with Fitbit.
How do I change the clock face? It used to work on my laptop.
Best Answer09-26-2020 06:25
09-26-2020 06:25
Thanks for the info...but when I open my Fitbit App I have neither a "clock" icon in the top right/left nor do I have an "account" icon...all I have is my Photo - top left
"Today" - top center
Edit tab - top right plus an "inbox" atop of that
Unable to switch faces...help!
Best Answer10-11-2020 08:17
10-11-2020 08:17
Tried this, now my Charge 3 will not turn on!
Best Answer11-02-2020 21:03
11-02-2020 21:03
I just figured it out. Got to your fit it app, then your face in top left corner. Select your device-fitbit 3. You will be able to see all your available clock fave options there. Good luck.
Best Answer11-06-2020 06:19
11-06-2020 06:19
I tried these steps to set clock face but not working when i select the face from all clocks. It doesn't move to next step and stuck there only.
