03-12-2022
16:23
15:27
03-12-2022
16:23
15:27
Sometimes the stopwatch pops up at randam. How do I access it on a regular basis?
03-14-2022 19:29
03-14-2022 19:29
@rcofdayton , Nice to see you around. Thank you for your message.
On your charge 4 when you swipe the clock face you'll see the Stopwatch/Timer app. Tap on it and swipe the display to select the feature needed.
Tap again to select your choice.
Hope this helps.
03-30-2022 11:07
03-30-2022 11:07
03-30-2022 18:51
03-30-2022 18:51
@rcofdayton Nice to see you back. Thank you for your further explanation.
You are correct. The timer on the Charge 4 can only run (play button), stop (pause button) and being reset (reset button)
Once you have stopped the time. press the button on the Charge 4. this should get you back to the menu.
If this doesn't work, try restarting the Charge 4
See you around
