01-31-2020
11:37
17:16
01-31-2020
11:37
17:16
How do I put my new charge3 on my app. instead of my old charge2
01-31-2020 12:48 - edited 06-07-2024 05:41
Hi there @Carolxi, thanks for stopping by.
While reading your post I was wondering if the mobile device you're syncing with is included in our list of supported devices? You can see the list at: Which phones and tablets can I use with my Fitbit watch or tracker?
Please keep in mind that when a device is not supported we cannot guarantee its functionality with the Fitbit app. It might work at a certain time and then it can stop working out of nowhere after an update. This is because the app is not optimized to that device and any change could impact the performance.
Please follow @SunsetRunner's recommendation or you can try the following:
1. Remove the old Charge 2 from the phone's Bluetooth settings.
2. Turn off other Bluetooth connections when not in use.
3. Plug it into the charging cable and open the Fitbit app.
4. Setup your Charge 3 as a replacement.
Keep in mind that if you are going to use the same Fitbit email address you used to use with your Charge 2, all your previous data will be stored on your Fitbit account (since the day you linked your Charge 2 until now). Once the Charge 3 is paired to the account, your dashboard will start syncing and showing all the information tracked from your Charge 3.
If you don't want to see previous data and want to start from scratch with your Charge 3, you'll need to create a new account.
01-31-2020 12:23
01-31-2020 12:23
See page 7 of your User Manual. In Adding the Charge 3, you will be prompted to replace the Charge 2.
01-31-2020 15:03
01-31-2020 15:03
01-31-2020 15:25 - edited 10-08-2023 09:11
Hi there @Carolxi, thanks for getting back. I'm glad to hear that you successfully linked your Charge 3.
In case you have some spare time, I would like to invite you to visit our Health & Wellness where you will find great tips and encouragement from other members and if there's anything else I can do for you, please keep me posted!
