03-20-2019
08:06
11:22
03-20-2019
08:06
11:22
Yesterday my charge 3 just stopped working for a while. I had to Google how to get the face turned it back on and get it to start working again. Now I cannot get the time corrected as it lost several minutes. Does anybody know how to change the time on a Fitbit charge 3?
03-22-2019
18:06
- last edited
yesterday
03-22-2019
18:06
- last edited
yesterday
It's great to see you here @joyrun and @N8teGee thanks for the input.
I appreciate all the efforts in trying to fix these display/timezone issues by yourself. I was able to see here that our friend @N8teGee provided some instructions in order to fix this time problem. Was this the answer you were looking for? If it was, I recommend marking the answer given as a solution. By doing this, other users with the same inquiry will be able to find a faster response.
Now if your inquiry/issue wasn’t resolved, let me know and I will be glad to help you out.
03-20-2019 08:47
03-20-2019 08:47
Hi @joyrun, welcome to the community.
The time on your Charge 3 should be determined by your phone, or whatever device its syncing to.
If you go to the fitbit app on your phone and do the following, it should hopefully use the correct time.
03-22-2019
18:06
- last edited
yesterday
03-22-2019
18:06
- last edited
yesterday
11-07-2019 11:44
11-07-2019 11:44
Ive followed the link suggested & it changes it but I want 24hr clock? Please help X tia
11-08-2019
05:20
- last edited
yesterday
11-08-2019
05:20
- last edited
yesterday
Welcome to the Community, @Shelster1973.
Regarding your inquiry, to change your timezone to 24 hrs, do the following:
Let me know if you need anything else. 🙂
11-08-2019 08:46
11-08-2019 08:46
11-08-2019 08:50
11-08-2019 08:50
Hi, thanks for taking the time to reply but ive got versa 2 with Alexa. Not charge. Brand new a few days ago & ive looked & on the time settings, it only says london gmt nothing for 12/24hr settings.
Regards
Shelly x
02-02-2020 11:42
02-02-2020 11:42
I followed instruction to change the time—now How do I sync Fitbit to device with the app?
02-08-2020 19:25
02-08-2020 19:25
You can't set the time because Fitbit is a piece of #$%$. Even the heart rate is not accurate.
02-09-2020 01:13
02-09-2020 01:13
02-15-2020 06:20
02-15-2020 06:20
How do I sync my Fitbit? Also does it work with iPod6’s?
03-01-2020 13:21
03-01-2020 13:21
I have a Fitbit Charge 3, I cannot change the time to 24 hour clock, any advice would be appreciated? Time now is 2120 hrs and the Fitbit says 0920 hrs. Thanks
03-01-2020 13:24
03-01-2020 13:24
There is no option to select 24 hr clock in advanced settings on Fitbit Charge 3?
06-14-2020 12:29
06-14-2020 12:29
I can’t get my Charge 3 to display the correct time or date. Help.
07-10-2020 18:18
07-10-2020 18:18
How do I reset clock
08-17-2020 06:10
08-17-2020 06:10
I am trying to reset the time and date on my Charge 3 Fitbit. I've turned on the automatic time set and then sync the fitbit. However, I get a red circles exclamation signal after syncing.
08-26-2020 13:43
08-26-2020 13:43
Hello,
I am trying to change the time to the 24 hour clock but I can’t manage to do it. I have read messages on here saying select the gear icon but I cannot find this? Can someone help please.
08-26-2020 14:23
08-26-2020 14:23
@Pat-O did you work how to do this? I am having the same problem, any help would be greatly appreciated
10-09-2020 07:56
10-09-2020 07:56
The solution didn't work for me at all.
It seems that when I get up in the middle of the night for a couple of hours, the fitbit charge 3 gets all confused!
syncing with phone did not correct it.
03-03-2021 14:49
03-03-2021 14:49
Thank you for the help, this fixed my problem.😊
