04-26-2019
20:35
11:08
04-26-2019
20:35
11:08
Just got my Charge 3. It appears I have the new dashboard and cannot find the + to set an alarm. How do I do this?
08-22-2020 20:22
08-22-2020 20:22
The “silent alarms” option has disappeared from the list on my charge 3 app. I have used alarms regularly for at least 18 months and now it’s gone. How do I get it back on the list?
08-22-2020 20:26
08-22-2020 20:26
Hi @Daktari alarms are now done from the device itself. Read this post from Fitbit Moderator - click to go there.
Best Answer08-22-2020 20:38
08-22-2020 20:38
Thanks, Odessy13. Big surprise. I did it, but it seems like a step back. It was definitely easier & more flexible when I could do it on the app.
Best Answer08-22-2020 20:40
08-22-2020 20:40
@Daktari someone posted in Feature Suggestions, wanting to have the ability back. Click to read and vote for it.
Best Answer08-22-2020 21:05 - edited 08-22-2020 21:49
Press the button at the side of your charge 3. When clock appeared, slide
left 3 times. You should see alarm on the top of screen. Tap on it . Then
you should be able to set alarm you want.
Hopefully, it will help.
Best Answer08-22-2020 21:09
08-22-2020 21:09
Hi @GNSC please return and edit your post. Your name and phone number are on it. Since this is a public forum, it's always best not to have such information made public.
Best Answer08-22-2020 21:36
08-22-2020 21:36
Best Answer08-22-2020 21:39
08-22-2020 21:39
@GNSC Feature Suggestions is a forum area where people post what they'd like to see and others vote on it. You can edit a post you make by going to it and pulling down on the upper right corner (three dots) and select "edit" and then click again to post it.
Best Answer08-25-2020 04:48
08-25-2020 04:48
This instruction no longer works on HR3 device. There is no "set alarm" option on the iPhone. I can see it and set one on the webpage....but it does not work or actually set an alarm on the HR3 device. So I suspect once again Fitbit is driving us all to pay for Premium service for a basic tool 😞 . thanks a lot!
Best Answer08-25-2020 07:31
08-25-2020 07:31
Hi @gztyp7 this thread started April 2019 and the information is old. The most recent change in the firmware and app now allows for the setting of the alarms on the device itself. There is no other way for you to set an alarm on your Charge 3. It's not a plan to make people purchase Premium, as it is all about breathing and exercise, not setting alarms.
Best Answer09-06-2020 06:25
09-06-2020 06:25
Best Answer09-06-2020 06:27
09-06-2020 06:27
Best Answer09-06-2020 07:35
09-06-2020 07:35
Hi @sunniedae the recent update now has the silent alarm on the actual device. It is no longer on the app.
Best Answer09-07-2020 20:19
09-07-2020 20:19
How do I reset my alarms to automatically come on for weekdays & not weekends? Do I now have to make sure it is set (or not) every night?! That’s crazy!
09-07-2020 20:28
09-07-2020 20:28
Hi @Fitnad71 read how to set your alarms here - click to go there.
Best Answer09-08-2020 07:42
09-08-2020 07:42
09-08-2020 07:44
09-08-2020 07:44
Best Answer09-08-2020 07:49
09-08-2020 07:49
@sunniedae please read how to set your alarms here - click to go there.
Best Answer09-09-2020 07:26
09-09-2020 07:26
Did the alarm setting disappear on the charge 3 dashboard? How to set Fitbit alarm on my charge 3 using IPhone
Best Answer09-09-2020 07:27
09-09-2020 07:27
The silent alarm icon has disappeared
