10-04-2020
12:31
16:17
10-04-2020
12:31
16:17
Hi, could you please advise how I can turn off my DND. I keep missing calls.
Thanks in advance.
10-04-2020 12:35
10-04-2020 12:35
Hold in side button a few seconds and tap 'DND'.
10-04-2020 12:35
10-04-2020 12:35
10-04-2020 13:38
10-04-2020 13:38
07:17
07:55
10-05-2020
07:17
07:55
Welcome to the Community, @Jg1696 and @JohnnyRow, thanks for the input.
I was able to see here that our friend @JohnnyRow provided some instructions regarding your DND inquiry. Was this the answer you were looking for? If it was, I recommend marking the answer given as the best answer. By doing this, other users with the same inquiry will be able to find a faster response.
Now, if your inquiry/issue wasn’t resolved, let me know and I will be glad to help you out.
Best Answer11-27-2020 11:15
11-27-2020 11:15
I’ve tried that. Doesn’t work. Please advise.
11-27-2020 11:32
11-27-2020 11:32
Hi, @LLV3.14 , welcome to the community, In more detail, the process is as follows. Starting from the clock screen on your charge 4.
I hope this is helpful.
Cheers
Gr4ndp4 | UK
11-27-2020 11:44
11-27-2020 11:44
I’ve done as you described. Do not disturb and sleep wake remain grayed out. (Yes, I’m tapping the icons.) There appears to be no way to turn them on from the Charge 4.
12-07-2020 17:52
12-07-2020 17:52
I had to turn Sleep off, then it worked. This answer gave me the info i needed to make it work!
01-06-2021 16:18
01-06-2021 16:18
I'm tapping and tapping and tapping and tapping on DND and it doesn't do anything? Now what?
01-07-2021 03:13
01-07-2021 08:44
01-07-2021 08:44
Thank you for your reply! What I actually figured out is I had accidentally turned sleep on so when I turned that off everything works again. I'm not sure how that happened though but if it happens again I know how to fix it.
02-05-2021 02:44
02-05-2021 02:44
Thanks for this final post - I had the exact same problems as you (tapping away without any luck until I turned off sleep) I appreciate the enlightenment!
02-10-2021 00:38
02-10-2021 00:38
Hi
This did not work for me. Screen wake also off. Any help appreciated
Thanks
02-10-2021 00:51
02-10-2021 00:51
Hi, @HMB4 welcome to the community, can you please describe your problem? Have you followed my earlier advice?
Let me know by posting here.
Cheers
Gr4ndp4 | UK
Best Answer02-25-2021 12:01
02-25-2021 12:01
Thank you! I was having the same problem. Didn't know how to get to the Screen Wake setting. Thanks for spelling it out.
02-26-2021 10:32
02-26-2021 10:32
when i tap on screen nothing but DND i held the side button scrolled up to screen wake tapped that. I can not get clock face or get off DND
Best Answer02-26-2021 11:06
02-26-2021 11:06
Hi, @karenjean1217, welcome to the community, a brief press of the side button will get you back to the clock screen (repeat if required).
Cheers
Gr4ndp4 | UK
Best Answer02-26-2021 11:32
02-26-2021 11:32
03-18-2021 13:21
03-18-2021 13:21
Finally, thank you for actually answering and explaining. I long for the One to come back.
03-30-2021
13:03
12:15
DavideFitbit
03-30-2021
13:03
12:15
DavideFitbit
Hi,
I have this issue and the DND is grey, but I cannot turn on. If I touch the screen, nothing happens!
can you advise please.
thanks
Hi, I have tried everything to receive notifications. Saying that I realised today that they are coming through but silently. So I attempted to find out how to fix this, and I discovered DND. How I turned it on, I do not know but I have read all the best answers and cannot turn it off. I have followed the best answer guideline with no success. I tap & nothing happens, it remains grey. Can you advise please.
