04-19-2016
05:11
18:03
AndreaFitbit
04-19-2016
05:11
18:03
AndreaFitbit
No matter how much I try to get used to it, the vibrate notifications when I reach 10,000 steps is more than just a nuisance, it's a hazzard! I was injured because of it. After a walk I was working in the yard and was in a necessarily awkward position while I was turning an underground valve. At the most critical moment the vibrate went off and my involuntary reaction to it tweaked my back. The problem is not with me, it's with this device. So this device which is supposed to help me pursue good health injured me. Is my only protection to change my goals to some unreachable number so I don't get shocked?
04-19-2016 06:08
04-19-2016 06:08
You could change your main goal to something other than steps. If there's something you don't care as much about, like floors or calorie burn, then you could set it to a higher goal but still leave your steps at 10k.
Best Answer06-02-2016 03:47
06-02-2016 03:47
I fully agree; vibration is such a nuisance. That's why I turn off call notifications and alarms on the Fitbit, and why I also disable all vibrations on my phone.
I have set my main goal as Steps and set it to a million (999,999 steps) as the maximum. I somewhat suspect that I could never reach a million steps in a single day, LOL!
07-26-2016 04:43
07-26-2016 04:43
@dweeb @PaddyLandau Your posts caught my attention since they have no reply and I'm sorry to hear that your Charge HR vibration feels uncomfortable. If you feel that the vibration is too intense, I recommend wearing your trackers a little bit loose so you don't feel the vibration so nuisance. If this doesn't work out, you might consider another Fitbit tracker such as the Surge or the Blaze, which have heart rate feature.
You can also try @kalimm's tips in order to avoid the intensity of the vibration of your Charge HR trackers.
Let me know if more questions arise my friends and I'll be around! ![]()
Best Answer07-26-2016 05:58
07-26-2016 05:58
@JuanJoFitbit Thank you for taking the time to reply, but I'm not made of money — I'm not going to buy a replacement product for this!
Wearing the product a bit more loosely is also not an option, especially as it doesn't solve the problem. Also as per my feature request (or, rather, remove-limitations request), I use the Fitbit to help monitor heart problems, not as a motivational buzzer.
@kalimm's reply is helpful, but it's a workaround, not a solution.
It is standard to be able to turn off vibrations on an Android device, and it should be standard for the Fitbit. It's kind of obvious, isn't it?
07-26-2016 07:03 - edited 07-26-2016 07:03
Duplicate 🙂
Best Answer07-26-2016 07:03
07-26-2016 07:03
@JuanJoFitbit In what world is buying another product wiht the same problem a solution? Unless you're trying to say that the Surge or Blaze have a way to turn off the vibration, I'm not sure what your point is.
08-09-2016 04:21
08-09-2016 04:21
@PaddyLandau @kalimm Hello guys, it is nice to see you again in the Fitbit community with us. Currently, it is not possible to turn off the vibrations on your Fitbit. I encourage you to vote for the following feature suggestion.
Thanks for your comments and participation, they are always welcome in the Fitbit community. ![]()
02-25-2017 19:35
02-25-2017 19:35
It's been close to a year, is there still not a solution to this simple problem?
05-16-2017 20:58
05-16-2017 20:58
I'm a MRI technologist and my Fitbit vibrations don't work anymore because I wore it too close to the magnet.. Fitbit still works! It just killed the vibrations. There is your solution 🙂 find a MRI scanner haha
01-14-2019 06:54
01-14-2019 06:54
Just got my Surge today an I already hate this vibration business more than I'd ever imagined. If FitBit doesn't move into the present, where people do not have to be pestered constantly by noises and feeling buzzing against them, then they've jumped the shark on devices altogether. Mine is buzzing even when charging. Annoying. We should be able to turn off like any other feature or alarm.
01-22-2019 05:44
01-22-2019 05:44
@asc_1 Thank you for joining us in this thread! I understand that this is frustrating for you. I recommend you to submit your request in our Feature Suggestions board and people can vote for it. The more votes your request gets, the more chances it will have to be reviewed by our engineers and developers.
I really appreciate your comments and feedback since this helps us to keep improving.
Let me know if you have any doubts!
08-06-2019 22:34
08-06-2019 22:34
I agree it's been driving me crazy. I don't think I will buy another fitbit
08-10-2019 12:18
08-10-2019 12:18
@MB7777 I'm sorry for the late response. However, thank you for participating in our Fitbit Community. I totally understand how you feel about this. Your feedback is greatly appreciated.
Best Answer08-27-2019 16:13
08-27-2019 16:13
I've been using my Fitbit for a month now. I like the heart monitor, the steps counter, and the sleep analysis but after trying everything to disable notifications I came here to find a way to stop the buzzer. Considering how long users have been complaining it's obvious that a correction won't be forthcoming.
For some people the buzzer probably helps keep them motivated. For those who are self-motivated already, it's just an annoyance. I've enjoyed the features but I will no longer be using it.
08-28-2019 07:58
08-28-2019 07:58
@alpaca100 welcome to our Fitbit forums! Your feedback is greatly appreciated since this helps us to keep improving. I understand how frustrating this is for you.
However, I'd like you to give your vote to this Feature Suggestion which requests the ability to turn off vibrate notifications. I appreciate your time with this.
I'll be around if any question arises.
Best Answer09-26-2020 22:30
09-26-2020 22:30
It’s absolutely ridiculous that there’s no way to silence the buzzing. Mine buzzes when anyone texts me while I’m sleeping!! You gotta have a way to turn that off in the Fitbit app, it’s so annoying and such simple software problem.
10-25-2020 13:28
10-25-2020 13:28
I have a very lightly used Fitbit Blaze (maybe a week of use total) in size L, Gunmetal series that does NOT vibrate since I forgot to take it off in the MRI scan room (I am a mri tech student). Everything else works perfectly.
I will sell it to you since I actually need a fitbit that vibrates (I use for morning alarm). Make me a reasonable offer if you want it. It will come with the original box, papers, and charger.
Thanks,
Steph
Best Answer01-15-2021 13:16
01-15-2021 13:16
I hate the vibrate.
I have a heart condition and it shocks me awake.
It was a gift so I would hate to toss it out.
02-11-2021 10:52
02-11-2021 10:52
I hate, detest the buzzing! Horrid, jarring, disgusting. Want it off permanently.
