08-20-2016
14:27
20:15
08-20-2016
14:27
20:15
How do we set the time??
Thanks very much
Moderator's edit: edited title for clarity.
08-21-2016 04:42
08-21-2016 04:42
Welcome to the Forums @Howtosettime. To setup your time, you just need to do the following from your Android Fitbit app:
1. Tap the Settings icon
2. Tap Account
3. Tap Settings
4. Turn off "Automatic time zone"
5. Tap Select time zone
6. Select your timezone
7. Sync
Let me know how it goes. ![]()
08-21-2016 04:42
08-21-2016 04:42
2. Tap Account
3. Tap Settings
7. Sync
08-21-2016 11:13
08-21-2016 11:13
11-06-2016 09:19
11-06-2016 09:19
Thank you for the info........helped me a lot.
11-11-2016 17:08
11-11-2016 17:08
Where is the settings icon???
Best Answer12-14-2016 09:44
12-14-2016 09:44
How to set time and wheere is the settings button?
Best Answer12-14-2016 19:48
12-14-2016 19:48
Lets find this together! I believe they are speaking about an Android phone and I have an Iphone 7+. I believe if we swipe to the left on our phones we will get to something along those lines.
12-14-2016 19:52
12-14-2016 19:52
On my iPhone I opened my app on my phone. At the bottom it says Account. I pressed that button then scrolled down to Advanced Settings. I then turned the Automated button off and then back on. Not sure if this will work or not.
Best Answer12-14-2016 19:53
12-14-2016 19:53
And it worked for me immediately. Hope that helps you.
12-17-2016
09:35
- last edited
10 hours ago
12-17-2016
09:35
- last edited
10 hours ago
Hey, @Cocoabean, @CathyDougWendy, @vjw_65! Thanks for joining in.
Like our friend, @Cocoabean said. This differs a little in the Android, and iOS platforms. To do the time change using an iOS device please do this:
Let me know if you have more questions.
12-29-2016 14:48
12-29-2016 14:48
set fitbit time using an iphone or mac
01-04-2017
05:30
- last edited
10 hours ago
01-04-2017
05:30
- last edited
10 hours ago
Hey, @merled! Welcome aboard. The steps to do it on your iOS phone are above and the steps for a any computer are:
1. Click on the gear icon at the upper right corner of your dashboard
2. Select the option "Personal Info"
3. Scroll down to "Advance settings"
4. You will find the option to change your Timezone there.
Let me know if you have more questions. ![]()
01-04-2017 09:10
01-04-2017 09:10
04:44
- last edited
10 hours ago
01-07-2017
04:44
- last edited
10 hours ago
Hello @merled, I hope you're doing well.
Because your tracker hasn't been able to sync, this is why the time is still incorrect on your tracker. I would like to suggest @HelenaFitbit's excellent tips to resolve any syncing issues and that have been proven very helpful for many members in the Community.
Give them a try and keep me posted in case you need anything else! ![]()
02-04-2017 17:52
02-04-2017 17:52
it is 2 hours slow, I wish to change it
03:32
- last edited
10 hours ago
02-06-2017
03:32
- last edited
10 hours ago
Hello @fit66, it's great to have you on board, thanks for joining the conversation! ![]()
If your tracker is syncing without inconveniences and the time is still incorrect, please open the Fitbit app and tap on the Account tab, then on Advance Settings and make sure Time Zone is set to Automatically or on your time zone. After that, sync your tracker, the time should update and reflect the correct one.
I hope this can be helpful, let me know the outcome! ![]()
02-06-2017 07:40
02-06-2017 07:40
03:49
- last edited
10 hours ago
02-07-2017
03:49
- last edited
10 hours ago
Hello @merled, I hope you're having a great day!
Thanks for taking the time to update me about this situation, I'm very glad you have a new tracker now. Did you contact our Support Team? If so, thanks for doing it! ![]()
In case you have some spare time, I would like to invite you to visit our Discussions board where you will find great tips and encouragement from other members. Additionally, if you need anything else, please feel free to reply.
Happy stepping!
02-27-2017 18:46
02-27-2017 18:46
Perfect.thank you
08:48
- last edited
10 hours ago
03-07-2017
08:48
- last edited
10 hours ago
Hey, @Retired2012!
I'm glad to hear that it worked perfectly for you. Now I would like to invite you to participate in our Discussion boards and share your interests with us!![]()
I hope to see you around.
