11-14-2017
22:14
20:15
11-14-2017
22:14
20:15
I started update and it did not finish now it does not sync with Bluetooth or app and has what looks like a download line across the front of it that’s only half way. I tried to reset it but it only shows that line
It's awesome to see new members in the Fitbit forums @Coleycoop. I suggest following these instructions:
Let me know if you have questions. ![]()
What's for breakfast?Check others recipes and share yours!
I’m having the same problem since tryin to do the update. It got half way through the update and stopped and line appeared down the screen. I’ve tried to reset and it just won’t let me do anything.
@Coleycoop, removing the Fitbit device from the account and factory resetting it are not necessary, and can cause more problems than it fixes. In most cases opening the phone's Bluetooth settings, selecting the Fitbit, and telling it to Forget the device will solve the problem. After the Fitbit app is re-opened, it will force the device to re-connect to Bluetooth, and it will normally restart the download of the firmware update.
Thank you!!!! Plain and simple instructions that work!!!!
All,
Here is what mine looked lik, half way through the download.
Here is how I got it to finish the download.
Go to your Bluetooth settings on your iPhone and find your tracker, tap the (!) exclamation point and select "Forget this device".
To pair your tracker's Bluetooth from the Fitbit app do the following:
From your mobile Dashboard tap the Account icon, bottom right
Tap your tracker's picture on the left side
Tap Notifications; move the slide over till it turns green, then a pop-up message should appear requesting permission to set up your tracker to your iPhone's Bluetooth
Tap Pair when prompted too
Let the download complete, be patience.
Now do a sync
ALAN | VAN,B.C. Canada Community Council Member
Versa, Charge, Charge HR, Ionic, Ace, Aria 2 scale, Flyer headphones - iOS
Click here Fitbit help for more solutions
Hello everyone, it's awesome to see you all participating in the Fitbit Community. ![]()
It's nice to see how our Fitbitters help each other! I'm glad to know that you were able to resolve the inconvenience with the firmware update, now that you're back on track, I'd like to invite you to continue digging in our Community, you can find here the option to suggest your ideas to change and improve our products and services, you can also find awesome discussions where you can make new friends, find other Fitbitters sharing their experiences and motivation and much more.
See you all around the forums.
Best AnswerMy charge HR is stuck with the block line. I have tried to restart. I have unpaired from blue tooth and app. Multiple restarts have failed and now charge hr is refusing to re-pair with blue tooth. Please fix. Why do my fitbits only last a year before dying? Frustrating.
Best AnswerMy Fitbit charge 3 does not update even after waiting an hour or more. I’ve read the suggestions to delete device from my iPhone Bluetooth. Am not getting the needed ! to enable deleting. Frustrated. Need advice on what to try next.
