11-28-2016
20:35
10:26
11-28-2016
20:35
10:26
After just one month, I lost my Fitbit charge 2. Is there a way to check by the gps to see where it might be?
Thanks!
Sorry for your loss. There’s no GPS in a Charge 2 (the Surge is the only model that has built-in GPS). There’s Bluetooth, but its range is very limited, so it could only be used if you’ve misplaced it at home.
The watch-like band of the Charge 2 makes it really difficult to lose it when wearing it. How did that happen?
Dominique | Finland
@Sls918 Welcome to our Community! Sorry to hear that you lost your Fitbit Charge 2. Adding to what @Rich_Laue and @Dominique have said there are some apps that will detect the bluetooth signal of your tracker. For iOS you can use the LightBlue app and for Android you can use Bluetooth Finder. Also check the last time your tracker synced, it may give you an idea of where you were at the time it came loose. Check your car, it is quite common losing the tracker inside your tracker and not noticing while you are driving. There are some additional suggestion in our help site.
I was writing my post while you replied so I will add that your tracker will sync with your phone or computer at a distance of 20 ft so it does mean that your tracker is nearby. I have seen cases in which the tracker is in the front yard as it could be dropped when you got out of the car. Use your phone and see where do you loose the signal and where do you get it so you can pinpoint the location. Also it happens a lot that if you were carrying bags, backpack or something like that, that your tracker may be inside it.
Let me know how it goes!
@Sls918 Great that you are already trying the bluetooth app, and since it is close hopefully you will be able to find it. Take your time and please do reply to let us know what happened.
Keep me posted!
Glad you were able to find it! So where was it?!
Dominique | Finland
@Sls918 Really happy to read that you were able to find your tracker and thank you for letting us all know which app you used! I am sure this can help other members who may find themselves in the same situation.
I'll be around!
@Sls918 Thank you posting again and let us know where you found your tracker. I knew cars can become black holes! Still happy for the good news.
I'll be around!
I stoped wearing my Fitbit Charge a few months ago as I bought an Apple Watch. Last time I saw it I was in my house, now I have come to want it again due to all my friends getting one. I have searched high and low and I can't find it anywhere. I'm guessing that the battery will have died. It's not connecting or appearing on my Bluetooth settings. I'm starting to feel like I may have thrown it away. 😅 Is there any other way of tracking it's current location. I have tried using the app you suggested but it doesn't seem to work, it spins and flashes in one area. When I move it doesn't move.
Best AnswerI used the free "find my fit bit" app which locates it via Bluetooth. First I had to go into my settings, Bluetooth, and disable my Fitbit from my phone. After that, the app was able to track it more easily. I was able to locate it with in just a few minutes. For anyone looking at this thread for advice, you don't need to pay money for a more expensive app . The free one works fine as long as you remove your fit bit from your Bluetooth settings.
Best Answer@TomRace16 of your tracker hasn't been used in Moines, it will be dead, these fond my fitbit apps depend on the tracker being alive and running. Since it has been several months your tracker will be dead and you will need to use your eyes to locate it.
Just in case: what @Rich_Laue means by "dead" is the battery will be totally discharged. The tracker itself may still very well be in working condition, if/when found and once recharged. But you’ll indeed need to locate it the old-fashioned way.
Dominique | Finland
I've lost my Fitbit and I've tried all the tracking apps but it doesn't turn up does that mean it's not nearby and when you try to Bluetooth sync what do you do ?
