09-10-2016 08:50 - last edited on 09-09-2020 10:26 by MatthewFitbit
New Charge 2
How do I view a map of a walk or run? I do not see the option to view a map on the app dashboard or on the website. I checked the log section on the website as well. I'm so lost.
Thank you
05-08-2017 12:42
05-08-2017 12:42
Correct @subteach55 thats why this is the Charge 2 area. If you want you can use the mobile run or walk in the fitbit app, this will give you a map.
05-08-2017 21:48
05-08-2017 21:48
05-14-2017 11:27
05-14-2017 11:27
I not sure how those that have their maps disappear will be able to explain where they go. As explained above do not press pause then press resume. If pause is pressed thrn the user must end tye session and start a new one.
05-15-2017 20:19
05-15-2017 20:19
Incorrect, I went for an 11 mile bike ride and hit pause a few times when we stopped for water or at the store. And then resume with no issues. But I'd like to know where the map went. I liked my path and would like to repeat it.
05-16-2017 03:24
05-16-2017 03:24
Last time i looked the app doesn't have a bike recording mode.Are you sure you where not useing the tracker?;
Now if you where using the app, your map disappeared because the event was paused then resumed.
05-16-2017 10:53
05-16-2017 10:53
05-16-2017 11:05
05-16-2017 11:05
You asked
@ChristianB70119 wrote:------- CUT --------
------ CUT -------
@ChristianB70119 are you still able to see the map, your question implies that you are not. I'm telling you that there is a known bug in the software and by pausing then resuming, the map will disapear, and you will not be able to see it later.
Now if the bike mode was started on the Charge 2, there will be no map until after tye tracker has synced, but it will still be viewable.
05-18-2017 07:07
05-18-2017 07:07
Stopped working. Last 3 days no maps! 😞
05-18-2017 08:41
05-18-2017 08:41
Hey @Toronto3 my I ask which of the possible 2 methods of recording your walk do you use? Did you start the recording through the Charge 2 or through the Fitbit App?
06-22-2017 06:20
06-22-2017 06:20
I don't have a problem with mapping my walks, I just want 2 know is it possible to recover the map after it disappears.
06-22-2017 06:43
06-22-2017 06:43
This all seems very confusing. I wish it all could be cleared up by Fitbit fixing the bugs to make it work right.
09-08-2017 22:28
09-08-2017 22:28
I am a beginner, and don't understand -- my dashboard doesn't show "walking" as an exercise. How do I find this map?
09-09-2017 10:28
09-09-2017 10:28
@PrairieRose, im not exactly sure if i understand.the auestion.
You first will need to go for a walk using the Multisport walk mode on the tracker woth the connected GPS on the phone.
Or
Use the Mobiletrack mode on the app.
Then after a sync, tap on the exercise tile and a list of your walks will show.
09-09-2017 13:57
09-09-2017 13:57
09-09-2017 15:13
09-09-2017 15:13
This feature worked really well, it showed the map after my walk. The last couple of weeks after I hit finish, it just shows a blank screen. It is recorded as a walk without a map when I check later.
09-09-2017 15:27
09-09-2017 15:27
I take a screen shot of it, and it goes into gallery on my phone. Then, I have it as a "photo." Works well.. I cannot however get it to log a bike ride and am also finding it doesn't hold it's charge all that long after a few months. As someone indicated below, it's all very complicated and reaching a point of my prob. just returning to old fashioned Ped.
09-09-2017 18:03
09-09-2017 18:03
@snmbs are you starting the tracking of your walk through the phone app or the Charge 2?
@subteach55 the Fitbit app does not have a bike mode, but Bike is one of the 19 events that can be added to the Charge 2 Multisport mode.
09-13-2017 19:25
09-13-2017 19:25
If you click on weekly exercise (with the little running person), up in the right hand corner next to the gear there is a thing that looks like a timer or stopwatch, click on that. There should be a statement that says "Enable location services to track" in a pink bar at the top, click on that. It will ask you to turn on location services to track your exercise with GPS. Click on "Open Settings". At the the top, where it reads "Location" it probably reads "never". Click on that to change it "always", or "while using the app". That should fix the GPS tracking issue when you are exercising.
09-13-2017 19:43
09-13-2017 19:43
09-13-2017 19:48
09-13-2017 19:48
You are very welcome!
