Mapping a walk
ANSWERED
New Charge 2
How do I view a map of a walk or run? I do not see the option to view a map on the app dashboard or on the website. I checked the log section on the website as well. I'm so lost.
Thank you
86 REPLIES 86
If you are like me and were looking for the maps on your fitbit charge 2 go on your fitbit app and on your dashboard under the big numbering of steps you made that day it says weekly exercise click that and then click the little plus clock looking thing and theres a map. In that map you can choose weather your running or walking.
Thanks... That's what I do but what I'm talkn bout is the map afta I'm
done...
@Janefondablack if your recording the walk through the Charge 2 then the map should not disappear
If your starting the tracking function through an android phone, ,it pause followed by resume was pressed. Then the map might be lost.
Oh... OK... That's exactly what I've been doing... I've been tracking thru
my Android & pause when I go n a store or something... Thanks so much, this
helps...
Tracking through the android app is not using the Charge 2 to track the walk.
You can use the charge2 .
Thank u... Someone gave me the info as 2 why it wasn't working
I'm still looking for it.
I'm still having an issue too. I stumbled into the map on 5/12/18 and the map is still recorded... i.e. I can still see it today. However, the very next day, I turned on location on my phone, turned on data on my phone, turned on Bluetooth on my phone, then started the walk tracking on my Charge 2... it tracked fine ... when I stopped, I held the button in, it said finished walk. synced... no map or option for a map on my cell phone app or on my desktop app... So frustrating!
ok... I have since read all the various posts... and think I have figured this craziness out... to track the walking... I can press the button on my Charge 2... until I get to the walk prompt... then hold it in to begin the walk........ THEN I must also activate my walk on my cell phone in the Fitbit app by going to Exercise (with running man image) and select the stopwatch icon in the top corner... then select the red circle "play" icon to begin tracking for the map. I will test this theory this week and see if I finally get this... ugh. too complicated.
Right & now My Fitbit is out of the warranty period...UUGGHH
Does not work. I walked over 10.000 steps today and wanted to show it on Google Maps. It's nowhere in the Android app@. I had my phone with me and GPS turned on. It simply does noy work.
Your Charge 2 has a phone icon that will display the status of the GPS. This status indicator will tell you if it is working .
I just recently updated my app on my cell phone & now it's working again...
it isn't there immediately after ur walk/run but it does show up n the
app... Try updating & c if that helps...
I started a walk, using the + button in the lower right corner of the
screen in the mobile app. It showed a map. But it's nowhere after finishing
the walk. That is weird. It is also not there in the fitbit.com-dashboard
(so, on the website). When will it be fixed?
There is no weekly excersize and no watch-like thing to click on. How do I get to see my map?
It has the phone icon. But still no maps.
Ugh... I forgot to turn location on my phone before my walk again today! We need a suggestion to the programmers to check to see if it is on... and if it is not, tell us. Other apps do it...
"ok... I have since read all the various posts... and think I have figured this craziness out... to track the walking... I can press the button on my Charge 2... until I get to the walk prompt... then hold it in to begin the walk........ THEN I must also activate my walk on my cell phone in the Fitbit app by going to Exercise (with running man image) and select the stopwatch icon in the top corner... then select the red circle "play" icon to begin tracking for the map. I will test this theory this week and see if I finally get this... ugh. too complicated."
@leklouy you should not have to track using both the Fitbit app and the phume .
On iOS i understand the app needs to be in memory, doesn't have to be in front.
On android Fitbit notification services need to be running .
Starting the tracking on both the app and the Charge 2 should give 2 logs for the one walk.
As for location services being off, when i start the android Fitbit app i get a warning
Just checked.. notifications are on for mobile. I'm using a Charge 2 and an android.
What phone do you have, if Android.
From the main screen
Tap the picture of your Charger 2
Tap notifications
.... Let me confirm ..
Oh no i spoke to soon, this has been removed from a recent Fitbit app update.
I'll test it later, but my thought is the Fitbit app needs to be in memory for the Charge 2 to get a GPS connection.
