09-10-2016 08:50 - last edited on 09-09-2020 10:26 by MatthewFitbit
New Charge 2
How do I view a map of a walk or run? I do not see the option to view a map on the app dashboard or on the website. I checked the log section on the website as well. I'm so lost.
Thank you
01-28-2019 11:46
01-28-2019 11:46
@Janefondablack that is using the Fitbit app to record the walk, not the Charge ,2, which is the question .
01-29-2019 03:58
01-29-2019 03:58
01-29-2019 05:38
01-29-2019 05:38
If I was going to start tracking a walk with the charge 2 I would do it from the Charge 2 and carry the phone in the pocket for the connected GPS, @Janefondablack. If I was going to track the walk with the Fitbit app then I would start the walk using the Fitbit app.
The result is the same using the Charge 2 you can monitor the start s durring the walk from the wrist, while using the phone app the stats may be monitored on the phone.
01-29-2019 13:47
01-29-2019 13:47
01-29-2019 22:13
01-29-2019 22:13
05-04-2021 12:42
05-04-2021 12:42
This option is only available in my app for 3 exercises: Walk, Hike, and Run. How do I select an option to track Bike? I would like to actually see the map while I am biking rather than only seeing the map after I am done with the ride.
05-04-2021 22:27 - edited 05-04-2021 22:28
@SteppingForPizz scroll up 3 posts and read my answer from January 2019 it will answer your question.
You want to use the exercise app on your tracker. You may have up to 20 exercises to choose from, one of which is bike.
