Network down
Can't log in or sign up. Network down?
4 REPLIES 4
I have the same problem.
I enter correct email and pasword in the Fitbit app and then get this Message: "Invalide email or password". No use choosing "Forget password", nothing is happening. I tried to log in on fitbit.com to check it out, and here my email and password is working. Is there any problems with the APP?
I have tried updating the fitbit app, but no change...
I can google my way to this site but if I try to log in to fitbit.com the screen goes gray.  Anoying, i just wantet to get nu akt together, haha
(Sorry for spelling so bad, i'm from Sweden..)
I found this under another topic here on the community: "Just switch off the wifi on your phone, and connect via mobile (if you can). I cannot current sync via wifi, but fine if I don't use wifi". I have switched off my Wifi and turned on mobildata. Then it worked! Why, I don't know. There must be a system error at Fitbit.
I have however no problems loging in on fitbit.com from the main page or when I log in to the community. Seems like there is a network problem, of some sort. If it's not the web browser?
