03-23-2019
08:35
16:45
03-23-2019
08:35
16:45
Is there a way where I can check heart rate from the tracker on demand and not always on? I noticed that if I set the tracker hart rate to on or auto mode, it monitors Herat rate all time to display when it is accessed. I’m looking at a function where only you press the heart rate and then only it monitor and shows the reading to save battery.
Or, turn on heart rate and turn off from the tracker without help from mobile.
@CanadaBoy Welcome! It's great to see you around!
Thank you for your inquiry. Currently this isn't possible but you can share your idea in our Feature Suggestions board. Search for the idea first to see if one already exist so you can add your vote. The more votes an idea gets the more likely the developers will try to implement it.
Let me know how it goes.
