09-16-2016
23:37
10:26
09-16-2016
23:37
10:26
Hi, so like others, my charge 2 is over counting, I've a small property and it's not 45 steps from bedroom to bathroom and I don't walk in my sleep, this morning I've woken to 168 steps! Mmmm something isn't right.
I bought the charge 2 yesterday, noticed before bed the steps were inaccurate, put it down to it 'getting used to my movements'. I've set it up as people have advised, less dominant hand, stride length etc.
Please can someone tell me if I've missed something, should I return it, was it a waste of money?
I know people that wear Fitbit and other brands and seem very happy, sadly I'm not and really like the concept of challenging myself, as I'm not confident to join a gym, but sure need to get fit.
Any advice much appreciated and thank you in advance.
Lee (soon to be fitlee I hope x)
Moderator Edit: Edited thread title.
Best AnswerFitbits are designed for averages. For every post you point to that says Fitbit is over counting, I can find you one that says it is under counting.
I used to worry a lot that my Charge HR was over counting, because I noticed that I got "steps" when I was introduced to people, when I spoke animatedly (I do tend to wave my hands around when I talk...), when I folded laundry.
I got so worried about it that I actually bought a Fitbit One (which is worn on yoyr body, so doesn't have the same issues as wrist worn trackers). The Fitbit One was recently rated as one of the most accurate pedometers on the market by the Journal of American Medicine, so I felt pretty sure it would give me the "true" idea of my steps.
I set my One up with a different email address and wore both my One and my Charge HR together for a couple of weeks.
The results surprised me. Although it is true that I sometimes got false hand steps from my Charge HR, it also turned out it missed some of my real steps, and the interesting fact was that over a week, the results were really close, and over a month, almost identical.. Furthermore, the more active I was, the more accurate my wrist tracker was..
So yes, if I sat around on the sofa all day and did nothing but eat pizza and drink beer, my "steps" weren't very accurate. 100 false steps in a 1000 step day is a 10 percent error. 100 false steps day in a 10,000 step day -- what is recommended -- is only a 1 percent error. Big difference.
Having said all that, for most people I would recommend wearing your wrist tracker on your non dominant hand, and, if it seems to be counting too many false steps, change the setting to dominant. So, for example, if you are right handed wear it on your left hand but tell the program you are left handed.
My other advice is to get up and move. The more steps you take, the more accurate your step count will be!
Best AnswerI'm completely new to fitbit, I literally only purchased the sleek looking Alta yesterday after my Jawbone up24 band died.. now the Jawbone was pretty darn accurate in that it wasn't too sensitive and therefore didn't record hairdryers or brushing teeth - if I wanted to cheat with it for some reason, I had to REALLY swing it.
I'm finding the Alta soooo sensitive it's ridiculous, it's telling me I've exceeded 10k steps today but I know my actual steps are likely to be less than 5k. I've got it on my dominant wrist (as I wore my jawbone) as my 'non-dominant' wrist isn't an option..
Will the Alta settle down or is there a way I can make it less sensitive while it's on my dominant wrist?
I appreciate NO wrist worn trackers will be 100% but to be K's off is ridiculous!? I'm also trying to tell myself that it's not all about steps but general movement too (all movement is healthy right!), but I'd still like a better idea of my daily steps, otherwise what's the point in having it!
TIA!
Best AnswerI've got my husband's Up Move on today, clipped on my ankle.. at 10:30am the Alta was showing I'd done 2522 steps whereas the Move was showing 718. I expect a difference due to hand movements but that's a massive difference!
Best AnswerI've had two Fitbits before upgrading to a Charge 2. The information from the ChargeHR transferred automatically to the Charge 2. Great! The HR was pretty accurate in counting steps. The Charge 2 under counts them by 20 to 25 out of 100. Help, please.
Best Answer@Profe550r wjen you say it undercounts 20-25 out of a hundred, is it every hundred or just the first hundred? Mine misses 10-15 steps in the first hundred, if i count off 500 or 1000 stepst it is still only 10-15 steps lost. I can live with this, but have brought ot tp the attention of Fitbit.
Best AnswerI spoke to support via Twitter about the Alta over-counting by thousands, they advised me to restart the band. I found my old jawbone up24 band and have been wearing that alongside the Alta for the last few days and can now say I'm a happy bunny! I always found the Jawbone pretty reliable and after comparing the stats for the last few days I can now say the Alta is good enough. Yesterday my jawbone was showing 5258 steps vs the Alta showing 5361. I personally can live with that difference as I expect there's always going to be a difference between bands! Happy with my purchase again now!
Best AnswerHi - same problem, but had already correctly set right handed and worn wrist etc. I get th the fact that the HR Charge 2 may overcount due to wrist movement (e.g. washing dishes etc) but sometimes it's WWWAAAY over! Eg. iPhone 6 correctly shows about 2000 steps and Fitbit shows 6 or 7000 sometimes higher...when I know I've had a very sedentary day. They are linked and synced...don't they 'compare' and agree..?
