09-16-2016
23:37
10:26
09-16-2016
23:37
10:26
Hi, so like others, my charge 2 is over counting, I've a small property and it's not 45 steps from bedroom to bathroom and I don't walk in my sleep, this morning I've woken to 168 steps! Mmmm something isn't right.
I bought the charge 2 yesterday, noticed before bed the steps were inaccurate, put it down to it 'getting used to my movements'. I've set it up as people have advised, less dominant hand, stride length etc.
Please can someone tell me if I've missed something, should I return it, was it a waste of money?
I know people that wear Fitbit and other brands and seem very happy, sadly I'm not and really like the concept of challenging myself, as I'm not confident to join a gym, but sure need to get fit.
Any advice much appreciated and thank you in advance.
Lee (soon to be fitlee I hope x)
Moderator Edit: Edited thread title.
Best AnswerI wonder if this will take care of my 19000 steps I got while riding my motorcycle? I could stick it in my jacket pocket and see if that works?
Best AnswerHi Focus, I have the same problem of over counting the steps. can you please explain how to get the latest version of the app? and also one more question I have, does the auto recognition has anything to do with the problem of over counting the steps? would disable this option help with the steps accuracy?
Best AnswerJulia, please advise me, I have the same issue, charge 2 over counts my steps, I exchanged it three times from the shop that I bought from, but every device gives me a lot of extra fake steps. Please tell me if I need to check the setting or to change anything in the settings.
Best AnswerThe step function seems like a total waste of time, so that makes me wonder about the sleep function mmmmm food for thought how do you check that???
Best AnswerHi - I bought my 1st Fitbit (Charge 2) having been a fan of UP4 for yrs. I'm now wearing both together and finding the Fitbit way overestimates my steps on walks where I know the distance. Today my Charge says 14011 so far and the UP says 10,100 which is about right. I will change stride length as its set at 171 at moment and I'm 171 1/2 height. I'm shocked at the difference as its substantial. I'm in rehab from multi ligament surgery so want to get it right so I don't overdo things yet. I love some of the Fitbit applcations but if I can't sort it by stride/changing/dominant hand etc will stick with my Jawbone as its great on sleep stats too but has major issues with band breaking over time - shame as I love the style of it - think it's discontinued now due to band issues and merger/takeover at Jawbone. Hopefully can solve overcounting on my Fitbit! Have used for about 3 weeks now.
Best AnswerThat's crazy and no you shouldn't need to remove it for driving/crocheting etc etc!! Mine still overcounts by 20-30% on a daily basis and overcounts calories used compared to my UP which doesn't record arm movements however fast. It also isn't good with HIT training - recorded 164 in gym on bike - Fitbit said 119 max for that, so way out. Apart from changing hand as we have done what other options???!! It's a shame as steps/hr are the key reasons we buy them!!
Everyone in this thread may want to up-vote this suggestion. It would solve a fair bit of your problems with over-counting. Turn step counter off and on, suggestion
Best AnswerOf course a workaround isn't optimal, but until there's a fix, a workaround is better than nothing.
Edit:
Dear Moderators,
Please remove the solved tag from this thread. This issue has not been resolved in any way.
As a software dev, I can say that it totally incorrect. Often a temp fix is made when the full fix will take a ton more time to implement. It buys time while helping the end-user at the same time. Simple logic. All or nothing is rarely a good idea, and shoots yourself in the foot in the meantime.
Taking it off is not an option when you still want the other features active. Example, when you're sleeping or when you want to keep an eye on your heart-rate. Taking it off isn't anything close to helpful or a workaround. At least a toggle would be functional and not cut you off from the other features.
