Re: Distance from Fitbit to Phone
I just set my Versa up and it will not sync more than 5 feet from my phone.  Suggestions?
12 REPLIES 12
Do you only sync through the phone. @MTGirl70
I should rephrase that....it won't call THROUGH my Fitbit unless I'm less than 5' away from my phone.  It will get messages, etc farther
I'm not sure what is meant by call through the Fitbit. what or who are you calling .
Do you only sync through one device, syncing a tracker through multiple phones or devices can cause interferance between them.
Let's say if a user syncs through both a phone and a tablet. if both or nearby the tracker could be talking to the tablet and will not be able to respond to a request to sync through the phone.
My phone can be in my hand and I will not get notifications...and it won't sync.  Haha...50 feet, me arse!
It sounds like their is a different problem @SUZIESPITFYRE.
Not knowing what phone your having issues with, I suggest looking at fitbits help.
How do I get notifications from my phone on my Fitbit device?
Receive call, text message, calendar, and other notifications on your Fitbit watch or tracker if you have a compatible phone.
My Fitbit device isn't receiving notifications from my phone
Try these troubleshooting steps if you're not receiving notifications
I was having the same issue I just bought it on Friday and couldn't get it to syn so I called Fitbit and they fixed the problem for me. I tried doing what it said online and it got me nowhere. I literally just got off the phone with them 15 minutes ago and now it syncs and gets notifications. I hope this helps. I have their number if you would like it
How was it sorted out
I don't know how they did it
Yes please
Moderator edit:  removed personal information
It looks as if this thread on how far communication with the tracker can go for notifications.. Has been officially hijacked by My tracker will not sync.
I'm going to pull out the hijacked posts.
The number for Fitbit is 877-623-4997
