03-18-2020
08:09
10:14
03-18-2020
08:09
10:14
I have called a couple of times about my Galaxy Note10+. It is not currently compatible with my Charge2. In fact, I was told it is not compatible with any Fitbit. The Note10+ has been out for more than 6 months and Fitbit has known about the problem for most of that time. This is an unacceptable delay and will cause me to consider alternatives.
03-19-2020 12:20
03-19-2020 12:20
Works fine for me... I have Note 10 plus 5G
Best Answer03-22-2020 05:16
03-22-2020 05:16
The compatible list is simply a list of the devices that have been tested, troubleshoot, and the app has been Modified to make work.
There are many phones not on the list that do work, maybe a few funcgions don't.
In any case I would treat this as a temporary error @IronJim.
Not knowinng what the issue is, we don't know how to help.
Best Answer03-22-2020 08:35
03-22-2020 08:35
When I try to sync, I get a message that says 'device not found.' I am unable to sync. In both a chat and a phone call to the help line, I have been told that there are no fitbits that are currently compatible with the Samsung Galaxy Note10+. It has been over 6 months that this has been true. That seems like a long time for a company as bit as Fitbit and a phone as popular at the Samsung Galaxy Note10+. Thanks.
Best Answer03-22-2020 08:36
03-22-2020 08:36
Correction: The message is 'No Device Found."
Best Answer03-22-2020 10:15
03-22-2020 10:15
Best Answer03-22-2020 10:28
03-22-2020 10:28
Fitbit doesn't make the tracker and phone comparable, they make the Fitbit app compatible. The tracker is already compatible with the app.
Best Answer03-22-2020 10:36
03-22-2020 10:36
Best Answer03-22-2020 10:45
03-22-2020 10:45
My phone was updated on 3/17 to version N975USQS3BTB3. Don't see developer settings nor AVRCP. Thanks.
Best Answer03-22-2020 10:54
03-22-2020 10:54
I have uninstalled the app, restarted the phone, and reinstalled the app. The app seems to install properly, I sign on and still get 'No Device Found.'
