11-08-2021
19:36
16:06
11-08-2021
19:36
16:06
My Fitbit screen brightness has faded so much that I can't see it hardly at all
06-04-2022 15:49
06-04-2022 15:49
06-10-2022
12:09
05:49
06-10-2022
12:09
05:49
Welcome to the Fitbit Community forums, @KCDoo.
Thank you for sharing your inquiry about the Charge 4.
You can find the instructions on how to change the brightness of the device here.
@Beckyhandy Thank you for sharing your experience with this. About your Charge 4 with the brightness problem, If you already tried all the recommendations mentioned earlier, I do recommend that you continue the communication with the Customer Support team. They have specialized tools and will let you know if there are any other options available for you. You can click here to get connected.
See you around.
09-18-2022 14:12
09-18-2022 14:12
Thank you for the instructions problem solved
13:05
05:49
10-11-2022
13:05
05:49
Best Answer11-26-2022 07:58
11-26-2022 07:58
This info worked for me! It was explained very clearly. Thanks!
08:00
05:49
12-10-2022
08:00
05:49
Welcome to the Community forums, @WanderingMK.
That's great news! Thanks for sharing this update.
Have a great day.
Best Answer04-10-2023 05:55
04-10-2023 05:55
I had this same issue and realized that I had mine on 'sleep' - feel kind of silly sharing but it it helps someone else to check that setting as well!
Best Answer07-10-2023 05:00
07-10-2023 05:00
My setting is normal and it still dims
Best Answer08-09-2023 09:27
08-09-2023 09:27
Hi, welcome to the Fitbit Community.
Thank you for the information provided abou this inconvenience with your Charge 4.
@doodlemomx2 It's great to know that you were able to get the screen back to a regular brightness setting. Thanks for sharing this update.
@Mbut Could you please confirm if you've also tried restarting the device or changing the clock face option?
