Screen keeps blinking from time to screen wake/notification
On yesterday I charge my watch as normal when I took it off the charger later that day I noticed the screen kept switching from screen wake notification to the time to blank and is continuous won't stop how do I correct this problem
26 REPLIES 26
Hello .. mine had 1 month left in the warranty so they replaced it (less the band). Bottom line there is no fix other than replacement. Based on my past history with Fitbit and our Aria scale being out of warranty (with issues) .... as long as you are in warranty you are OK ... if not
they are not much help
Sent from my iPhone
I followed these instructions but didn’t help. It is still jumping back and forth to the different screens.
Hello,
I woke up this morning and my fitbit was showing a 0% charge which was odd as it was well charged before I went to bed. I pulled in my Charge 3 fitbit but since this morning, it's not charging, not syncing and now it's flashing Screen Wake/Notifications to the time which is still at 7:58 am. I tried cleaning the posts as instructed on your website, still nothing. I tried re-starting it; didn't work. It would not shut off. I unplugged and replugged. Now, it showed me a happy face, then one flash of the SW/N message and then, a flat line across the screen?? What's happening?
Thanks in advance for your help.
Hi you’ve contacted a customer not a customer advisor. I had to send mine back as it was in warranty and I was sent another unit which has worked fine. I found on this community that the fault your experiencing has happened to many FitBit Charge 3’s. I hope you sort it out.
James
Sent from my iPhone
Unfortunately I think that was your Fitbit saying goodbye, Lol! You'll probably need to call customer service, the number should be on your app. They were very helpful and sent me out a replacement in a couple of days.
Sent from Yahoo Mail on Android
My watch just started doing that as well I've tried to do the 5-second restart the 15-second restart nothing seems to work what do I do now??
Hello,
Once I finally got a hold of a human at Fitbit, they told me to just mail the tracker back to them and they replaced it As I still had a month left on my warranty .. I had to take off the watch band and send only the tracker.
They never explained what the issue was. If yours is out of the warranty period, I doubt they will do a replacement. It seems a year on any of their trackers is about all you get out of them.
As a side note There’s a reason Best Buy stopped their no questions extended replacement insurance on Fitbit trackers... they were losing money.
I’m not one to buy extended insurance on items but in the case of Fitbit I did and ended up using it quite a lot until it no longer was an option. Was much easier to return/replace the broken ones at Best Buy vs trying to get a hold of Fitbit.
Sent from my iPhone
