10-14-2018
17:31
15:06
10-14-2018
17:31
15:06
After downloading the new firmware for the Charge 3 my screen no longer wakes when rotating my wrist. I either have to double tap the screen or press the side button to wake the screen. Holding the side button in no longer takes me to a menu either. The device just vibrates 3 times when the side button is held. I restarted the device and continue to have the issues.
Any recommendations?
10-14-2018 17:38
10-14-2018 17:38
Have you tried holding button down twice? That should bring up screen wake page. If it isnt already turned on, turn it on.
10-14-2018 17:38
10-14-2018 17:38
10-14-2018 17:40
10-14-2018 17:40
Sorry. I meant hold button until it vibrates twice.
10-14-2018 17:47
10-14-2018 17:47
Yes, it actually just worked and I was able to fix it. I tried several times today and it would just vibrate 3 times rather than take me to the menu.
Thanks!
10-15-2018 08:14 - edited 10-18-2018 08:12
How did you get it to work? I noticed this issues as well the past few days. I noticed I could access the quick settings once randomly last night in bed. Now I can't at all. It just vibrates a couple of times, and so on.
Edit: I soft-reset the watch by plugging into charging cable, held button down for 8 seconds, released (saw smiley face) and then let it reboot. I immediately noticed that the Quick Settings were back to normal, and I was able to fix the wake screen setting. I'd recommend others try this too.
10-15-2018 11:10
10-15-2018 11:10
Thanks for helping Chris! I had the same problem. Your instructions fixed it so easily. Thanks, koolforkatz!
Best Answer10-15-2018 19:40
10-15-2018 19:40
My screen is black and dosent turn on no matter how many times I flick my rist hold down on the side or tap!
i had this problem before and I restiveness ot to this one but same problem any suggestions
Best Answer11-25-2018 21:16
11-25-2018 21:16
I had the same problem and your solution fixed it in 2 seconds. Thank you!
Best Answer11-27-2018 07:32
11-27-2018 07:32
There is no quick view option in my settings and I'm having to push the side to get the clock face to come on as well as to view who's calling and text messages. I have the Charge 3. Help!
11-27-2018 07:39
11-27-2018 07:39
I also don't have a screen wake button.
Best Answer11-28-2018 13:29
11-28-2018 13:29
Thank you! That worked perfectly. It was frustrating to not find that with all the other settings.
Best Answer11-29-2018 09:02
11-29-2018 09:02
I was experiencing the same problem but your reply helped me fix it. Thanks.
Best Answer11-30-2018 00:19
11-30-2018 00:19
Oh and check if you have "wake mode" on by pressing the side button few moments. There should appear Wake Mode and Notifications-page after pressing the button.
12-03-2018 23:52
12-03-2018 23:52
Press side button. Twice and will bring wake up screen
Press and will work
Best Answer01-10-2019 20:50
01-10-2019 20:50
Did it suppose to switch screen rotation off during sleep hours, when notifications are also off
Best Answer01-14-2019 09:02
01-14-2019 09:02
It seems that I have to turn my wrist in just the right manner to get the watch face to come on. If I flick it too fast, it won't come on. Works best when turning slowly which is a real hassle to always have to be aware of how quickly I turn my wrist. I usually end up tapping it or pushing the button on the side. If i have a watch on my arm, I want to be able to see the time without having to think about how to get the face to light up. Possibly the developers could work on this issue.
01-16-2019 10:49
01-16-2019 10:49
I had the same problem and this solution fixed it.
For those who didn't see, when you hold the button for a few seconds there are two settings to manage, the "screen wake" and the "notifications". When they're off, they are dimmed down!
01-17-2019 13:52
01-17-2019 13:52
I'm aware of the Screen Wake setting and it's set to on but I still have issues with the watch "waking" up when I turn my wrist to see the time.
01-25-2019 14:52
01-25-2019 14:52
Worked. Thanks.
Best Answer02-10-2019 19:49
02-10-2019 19:49
My screen wake feature is set to on, but doesn’t seem to work since charging my device. Any suggestions?
