Screen repairs?
Hello.
Somebody know where I can repair or change screen in fitbit change 2? Mine is broken and I don't know what I can do with this.
29 REPLIES 29
yes I have tried this product - not very touch sensitive.  I keep forgetting to put it on when I'm doing yardwork.  My bad!
thx...just looking to protect it mostly use the side button
Then  it should work for you.  It's not very expensive and worth a try.  Yvonne
thanks   Yvonne
Same here. They had no option of repairing the screen and offered discount to buy a new one.
got these instead much cheaper easy to put on and screen is sensitive took 19  days to get from china  https://www.ebay.com/itm/Ultra-thin-Soft-TPU-Screen-Protector-Case-Cover-for-Fitbit-Charge-2-NEW/254...
Called customer support today.  No option for screen repair.  It basically shattered for no apparent reason, while swimming.  I was offered a discount to buy another one.  Huh?  Buy another faulty product w no option of repair??
I know, it's crazy. For a £120 watch, you'd expect there to be replaceable parts. Not very environmentally responsible either.
Fitbit is piece of Garbage, I had Problem with three different fitbit just after a year!!
