08-30-2018
		05:09
		18:22
		08-30-2018
		05:09
		18:22
My charge 2 keeps shutting off and I can't keep it on without restarting the device is it just the battery getting old?
08-30-2018 09:32
08-30-2018 09:32
Does it show a full charge? How long does the battery last? Did you allow it to discharge completely?
		09-03-2018
		12:45
		09:01
                                          Community Moderators ensure that conversations are friendly, factual, and on-topic. We're here to answer questions, escalate bugs, and make sure your voice is heard by the larger Fitbit team.  Learn more
		09-03-2018
		12:45
		09:01
@Dalton15 Welcome! It's nice to have you on board! Sorry to hear that your tracker isn't working fine. Besides the information @SunsetRunner requested I would like to add that you can try cleaning the trackers contacts. Fully charge it by plugging it for a couple of hours and restart your device.
Let me know how it goes!
 Best Answer09-07-2018 04:03
09-07-2018 04:03
I have the same problem. It literally started last night. I charged it to full. Then shuts off after approximately 15 minutes. Sometimes the battery power seems to drop a bit sometimes not. When I plug it in it acts as if it’s been reset.
09-07-2018 06:05 - edited 12-19-2024 09:01
Hey there @WBillM, it's nice to see you around!
 While reading your post, I was wondering if you've followed the tips and recommendations that @AlvaroFitbit has shared in the post above?
As per the description of your post, it seems that it has insufficient power source. Where do you charge your tracker? Have you checked if by any chance the USB port or outlet is faulty? If you haven't done so, try a different port. A UL-certified wall charger will also work. Don't use a USB hub.
Also, I was wondering if while charging you see the battery icon on the display? Are the green lights on the back still flashing?
Looking forward to your response!
Was my post helpful? Give it a thumbs up to show your appreciation!  Of course, if this was the answer you were looking for, don't forget to make it the Best Answer! Als...
09-07-2018 15:35
09-07-2018 15:35
I have been charging it exactly the way I am always charged it. I let it charge all day today. When I took it off charge it worked perfectly fine for about 15 minutes and then it was dead.
09-09-2018 07:45
                              09-09-2018 07:45
Thanks for confirming that @WBillM! I was about to create a support case on your behalf, but it seems that you've called our Support Team last Friday. ![]()
Please always keep an eye on your inbox as you will receive new updates in the following days.
In case you have some spare time, I would like to invite you to visit our Discussions board where you will find great tips and encouragement from other members and if there's anything else I can do for you, please keep me posted!
		09-09-2018
		17:57
		05:29
		09-09-2018
		17:57
		05:29
Mine started doing this exact same thing this morning. I followed all of the above steps, and it would just shut off after 15 mins. I plug it back in and it acts like it was reset with a completely drained battery. I fully charged it, reset it, then fully charged it again, took it off the charger, and started wearing it and it shut off again after 10-15 mins. It is about 1 year 9 months old. The green LED lights stopped flashing when it shut off. I repeated this 3x today.
09-10-2018 05:51 - edited 12-19-2024 09:02
Thanks for jumping in here @PopeTrox67, welcome! Also, thanks for taking the time to troubleshoot this inconvenience with your battery. Nice way to go!
Since it seems you've exhausted all the steps in order to fix this, I have reached out to our support team and created a case regarding your inquiry. Someone will be reaching out to you within the next 24-72 hours with next steps. ![]()
Point me out if there's anything else I can do for you in the meantime.
		09-10-2018
		15:26
		05:20
		09-10-2018
		15:26
		05:20
The green lights are flashing now. All I did was leave it off all day, and then charged it for 30 mins. It has only been about 5 mins so far, and so far, so good this time.
Not even 10 mins this time. I think the battery is shot.
 Best Answer09-11-2018 05:28 - edited 12-19-2024 09:02
Thanks for providing those details my friend @PopeTrox67! Please keep an eye on your inbox as next steps were sent to you.
Any doubts, make sure to include them on your reply to our Support Team.
Hope you have a great day!
09-11-2018 20:13
09-11-2018 20:13
Thanks for opening a ticket. I need the steps for my wellness program at work so the sooner I can make them count again, the sooner I can get to the step thresholds for cheaper insurance premiums.
09-13-2018 13:59
09-13-2018 13:59
I am not seeing anything in my inbox for this. Can you email them to me at granttroxel@att.net?
I have not received any follow-up communication yet.
09-18-2018 16:43
09-18-2018 16:43
I am the same user as PopeTrox67. I just realized I was logged in under my wife's account!!! I never received any contact from the support team regarding this issue. Please apply the comments from PopeTrox67 to this account.
09-18-2018 19:25
09-18-2018 19:25
Mine just started this tonight its been working fine and then it shut off no lights on nothing. I charged it and it will show i have a full battery. Then after 5 minutes it shuts off again. I tried resetting it and its still doing it.
06-22-2019 16:46
06-22-2019 16:46
Hi,i am experiencing the same thing mentioned above with the users,my fit bit pro 2 started shutting off all of a sudden,i put it on and then in 2 min time shuts down again,please help!
 Best Answer05-29-2020 06:52
05-29-2020 06:52
Same problem with me! it’s been happening x3 days. I’ve updated the tracker and have been charging it frequently. When I turn it on and check on the app it says 91% charged yet it turns off every 10-15 mins as well. Most of the time it’s on it vibrates and when I look it’s not tracking my HR. Mines 1 year old and I hope that it’s not simply too old, it’s a bit expensive to only last a year.
		06-18-2020
		08:57
		09:02
		06-18-2020
		08:57
		09:02
@Louise32 I hope you're doing well!
Let me help you with your Charge 2 tracker losing charge quickly and thank you for troubleshooting this issue. Since the issue persists I have created a ticket so our Support team can further assist you via email.
Let me know how it goes.
 Best Answer06-24-2020 08:44
06-24-2020 08:44
Hi Fitbit, I have also faced the same issues as the other users in this thread, trying multiple times of recharge and also trying to clean all the contact charging points.... please help!
		07-07-2020
		12:01
		09:02
		07-07-2020
		12:01
		09:02
@ronnieghm Thanks for stopping by!
Let me help you with your Charge 2 turning off and thank you for troubleshooting this issue. Since the issue persists I suggest you let our Support team know about this. I noticed that you already have a ticket with them so keep working with the team to find a solution.
