12-31-2016
11:25
10:13
12-31-2016
11:25
10:13
What setting/activity do you select when doing Les Mills Bodypump and Body Combat? What about C.O.R.E class? Want to make sure I'm getting the most accurate info! TIA
I did a bodypump class after another class but this wasn't tracked. Workout option was enabled.
It appeared to be tracked last night and my app showed 90 mins of exercise activity. This morning this has changed to 30 mins.
Do I need to manually select an exercise setting before I start the class?
@topcatZ I hope you're doing well! In your case you can select the workout option on your tracker by pressing the button until you see an exercise name then tap the tracker (not the button) to scroll through the different options, select workout by long pressing the button and once you finish your exercise long press it again to exit this mode. Once your tracker syncs you should see this data on your account.
Let me know how it goes!
Best AnswerIt works if selected manually but that really defeats the point of it being enabled automatically as advertised functionality by Fitbit. It sounds like the software needs improvement!
Best AnswerI can't find any option similar to "body combat" or "HIIT". I only see: run, walk, swim, weight, cycling, run in machine. Which one would you recommend for these 2?
Thanks!
