12-29-2016
13:51
10:13
12-29-2016
13:51
10:13
I currently have the Flex and trying to set up Charge 2. It's asking for 4 digit numbers for pair your tracker. where do I get that number? I thought maybe it was a pin number I make up but it's not.
Best AnswerUsually when you are pairing 2 devices using Bluetooth, it sends a code to one of them and you enter that code into the other. Like a password, so it knows that you have both devices etc. A way of stopping people just pairing with anything.
Best AnswerGreat stuff. Hope you like it. 🙂
Best AnswerThanks so much! Blindingly obvious really, but I hadn't worked it out.
@tgray69 wrote:I currently have the Flex and trying to set up Charge 2. It's asking for 4 digit numbers for pair your tracker. where do I get that number? I thought maybe it was a pin number I make up but it's not.
@ElsBellekens63 @freelancehuman Welcome to the Fitbit Community! I hope you're doing well!
@ElsBellekens63 are you having issues setting up your Charge 2. As @freelancehuman and others have mentioned the code can be found on the Charge 2 itself. Feel free to follow these instructions to setup your tracker.
Let me know how it goes!
Best AnswerI have put up the battery… and when i look at the fitbitt charge 3 is see fitbit.com/ set up.... on the fitbitt
Best AnswerI have a problem when pairing my Charge 2. The app stays blocked in the pairing fase after the 4 digits code. Doesn't want to pass after that step.
Any ideea?
