07-15-2022
19:29
14:11
07-15-2022
19:29
14:11
I'm having problems properly synching my Charge 4 fitbit to my new Strava account. I've followed the linking guidelines available online and both on my Fitbit and Strava accts it says they are connected. So it looks like there should be no problem. But when I go for a run, logging it on my fitbit watch without bringing my phone, the exercise data won't go to Strava--but it will go on my Fitbit app as two separate runs. Does this make sense to anyone? Thanks!
07-19-2022 15:29
07-19-2022 15:29
@MunchieLondon , Thank you for your reply.
Your answer confirms my suspicions. As you see, the data recorded with the app, got the map, so it was using the GPS.
The data from the Charge 4, don't show any map, meaning, GPS was recording any data.
As only the data with GPS info is sync between Strava and Fitbit, you only see, right now, the data from the phone.
Please try these steps to try to reset the Connected GPS connection between your Charge 4 and cell phone.
Some you might have done already but the order is important.
Make sure that the Fitbit app is allowed to run on the background and with the cell phone display off too.
Try to record another activity with connected GPS.
Hope this helps
07-15-2022 05:44
07-15-2022 05:44
If I record a run from my Fitbit watch, it won't automatically sync to Strava. GPS is on.
However, if I record a run from the Fitbit app on my phone it syncs fine. I used to be able to do both without issue.
Any idea on how to fix this please?
07-18-2022 18:27
07-18-2022 18:27
@MunchieLondon @mgoff357 , A warm welcome to the Community! Thank you for your messages.
In order for the Activities to be synced with Strava, you'll need:
To have both accounts linked (Fitbit &Strava)
Record the activities with a GPS connection.
Sync the Tracker with the Fitbit app
Then the data will be synced with both accounts.
@MunchieLondon, when you record your activities do you see on the summary in the Fitbit app a map?
See you around
07-19-2022 01:07
07-19-2022 01:07
Hi. The accounts are definitely linked. If I record a run using Fitbit app on my phone then I see a map and it syncs to Strava. If I record a run from my Fitbit watch, then I don’t see a map and it doesn’t sync to Strava. Both used to work fine. I haven’t changed the GPS settings
thanks
07-19-2022 15:29
07-19-2022 15:29
Hope this helps
07-23-2022 01:46
07-23-2022 01:46
That’s worked! Thank you 😊
07-24-2022 18:35
07-24-2022 18:35
@MunchieLondon , Thank you for your reply. I'm glad that the information helped.
Wish you a lot of fun with the Charge 4.
See you around.
