05-15-2020
14:41
09:40
05-15-2020
14:41
09:40
I get a msg saying I can't use this ver. of the software. I get an upgrade button but but nada happens when I press it. Haven't recorded activities for the last 7 or so hrs. Ran two miles in the a.m. and climbed 100+ flights of stairs. Nothing!
05-15-2020 14:49
05-15-2020 14:49
Mine stopped syncing last Friday. I can not reach any customer service.
05-15-2020 16:35
05-15-2020 16:35
As of 1730pm tonight (Utah time) I can now access my FB dta.. . . was getting nervous about no dta being seen or recorded earlier.
05-15-2020 21:18
05-15-2020 21:18
Hi, mine is the same. My iphone updated last night & I can’t synch despite trying everything on the site & forums... let me know if you get any tips on this please as I can’t afford a new one. 😱
05-15-2020 22:15
05-15-2020 22:15
I deleted the app on my iphone and then downloaded it again. It synced once then but now it will not sync any more once again. This is maddening. I can not afford to buy a new one either. Mine is not that old either. 😡
05-17-2020 19:00
05-17-2020 19:00
05-17-2020 20:09
05-17-2020 20:09
I’m in the same boat. Will NOT sync. Tried all the suggestions. Won’t connect to Bluetooth!
05-18-2020 16:28
05-18-2020 16:28
Best Answer05-19-2020 06:30
05-19-2020 06:30
Problem solved. Methinks it was due to the upgrading of my phone to OS 12.4.6. Either Apple or Fitbit corrected the problem All is back to normal and happy to find that I lost no Fitbit dta.
Best Answer05-19-2020 06:46
05-19-2020 06:46
Wish that was the case for me. My app keeps telling me no device found. Although if I try to add it as a new device it finds if but won’t sync. 😞
05-19-2020 06:58
05-19-2020 06:58
Best Answer05-19-2020 09:47
05-19-2020 09:47
did you have to reinstall, or did it just happen? mine is still not syncing...….still looking for device.
05-19-2020 10:27
05-19-2020 10:27
Best Answer05-19-2020 22:19
05-19-2020 22:19
This is maddening! So i finally got it to sync on my ipad but now the only stat showing is calories! Steps are gone as well as everything else I tracked like stairs etc! There is no
05-20-2020 00:15
05-20-2020 00:15
Best Answer05-20-2020 11:57
05-20-2020 11:57
I used your suggestion and mine also will sync to iPad but cannot sync to phone. And you’re right MADDENING!!!
Best Answer05-20-2020 15:18
05-20-2020 15:18
Best Answer05-21-2020 02:04
05-21-2020 02:04
Mine does not sync either
Best Answer05-21-2020 08:56
05-21-2020 08:56
Yesterday, my FitBit was syncing just fine. Today, not at all. I use a PC and the FitBit app (with dongle) to sync. When I have trouble I bring up the FitBit app directly and can usually sync through the "Sync Now" button. Today it says "No internet connection found." Since I am sending this post from the same computer that I am using to run the FitBit app, I clearly have an internet connection.
My guess is that FitBit has been pushing out some buggy updates lately. Last week, the hourly notification that occurs if I have not done my 250 steps stopped working. Now the sync app does not seem to be able to connect to the FitBit server.
FitBit never seems to stop trying to convince me to switch to another company's product.
Best Answer05-21-2020 09:18
05-21-2020 09:18
I called FitBit support and tried what they told me but no luck. First, my device would sync on iPhone 6 but not iPad. Now my iPhone installed the new IOS so the Charge 2 won;t sync anywhere. I tried the FitBit update from 2 days ago but no luck. Deleted and reinstalled FitBit app to iPad but no luck. And now the steps icon has disappeared an the device shows calories instead. If FitBit doesn't fix this, I'll have to try some other company's device and app.
DON'T BUY A NEW FITBIT! This a software problem. I think buying a new FitBit would be a WASTE OF MONEY!
