01-01-2017
		07:04
		10:13
		01-01-2017
		07:04
		10:13
Hello!
How can I track my Yoga classes? In the menu I dont have this point (Run, Weights, Treadmill, Workout, Elliptical, Bike, Internal Workout, but no Yoga)
07-06-2018 06:25
07-06-2018 06:25
In your opinion which Fitbit is the easiest to log yoga classes? Thanks
07-06-2018 06:40
07-06-2018 06:40
11-28-2018 18:21
11-28-2018 18:21
When I hit settings on my Alta HR nothing happens. I went into activity, exercise, everything and can't find yoga anywhere.
 Best Answer01-04-2019 10:45
01-04-2019 10:45
Not sure if this has changed but I can't find this either on the moble app or the online dashboard.
 Best Answer01-24-2019 03:12
01-24-2019 03:12
Hey, what were you doing wrong? I get the same - second day in a row and it does track my yoga. Thanks!
 Best Answer01-24-2019 07:07
01-24-2019 07:07
It wont autodetect yoga. You have to add Yoga as an option through the device settings, and then manually start it on your tracker. Google a bit on adding exercises and you should find it. Good luck.
 Best Answer01-24-2019 07:47
01-24-2019 07:47
Thanks.
Ive added yoga to the tracker and I start/finish it at every session, but it doesn’t go towards my total exercise minutes on the app. Maybe someone else has had similar problems? Thanks!
 Best Answer01-24-2019 08:02
01-24-2019 08:02
 Best Answer01-24-2019 08:31
01-24-2019 08:31
01-24-2019 08:43
01-24-2019 08:43
Thank you
