02-10-2019
03:05
11:25
02-10-2019
03:05
11:25
Which mode on Fitbit would be the best to record Aquafit excersise ? 😊
02-11-2019 03:20 - edited 09-25-2024 16:46
It's nice to see you around here @Biv! You can start tracking the activity by opening the Exercise app, then swipe left to find the exercise of your choice. If you want to track your Aquafit/Water Aerobics activity, I would suggest to select Workout. Tap the exercise to select it. Follow these steps to finish the exercise:
I hope this resolves your inquiry, if there's anything else I can do for you, please feel free to reply.
Best Answer02-12-2019 01:29
02-12-2019 01:29
Hi, thanks for the reply.
Do you mean treadmill as I can’t find workout mode? 🙂
Best Answer02-12-2019 08:32
02-12-2019 08:32
There is a workout mode, it's on your exercise shortcut set up. There is also an aqua jogging when you log exercise so you could maybe log it after as that?
Best Answer02-12-2019 10:04 - edited 09-25-2024 16:46
You're very welcome @Biv! You have the Workout option, but if it's not showing up on your Charge 3 you'll need to manually add it.
You can choose from over 15 exercise types—including run, interval workout, swim, and yoga, to customize the app with your favorite workouts. If a specific exercise isn’t available, choose workout as your exercise type. However, on the device itself you can select up to 6 exercises only.
Fitbit app:
Fitbit.com Dashboard:
Thanks for your help @rach05_123!
Hope this helps!
02-20-2020 13:21
02-20-2020 13:21
Hi, how do we add water aerobics as an exercise shortcut?
