02-22-2016
03:59
17:01
02-22-2016
03:59
17:01
My fidbit racks up steps, calories, floors when riding my motorcycle, even if iI place it in my saddlebags its still racking!!
Moderator Edit: Updated title for clarity.
04-14-2016 05:27
04-14-2016 05:27
Does the Fitbit Charge HR have a shutdown option? I am experiencing the same problem of steps being logged and stairs. This morning on my 45 motorcycle ride to work, I got 3500 steps and 50 flights of stairs. This is a problem when I'm in challenges with my friends. I don't want to "cheat", and the challenges are a big help to my week. Please fitbit, come up with a solution for us!
02-22-2016 04:20
02-22-2016 04:20
How many steps @Josie24? That's pretty much inevitable while driving any vehicle, probably more so a motorcycle, where you're subjected to much more vibrations from bumps along the way. The 3-axis accelerometer chip inside your tracker is a very sensitive instrument and for sure, some of these bumps could fool it into recording steps. You can delete those steps by logging a manual driving acivity, as described in Can I delete data . Hope this helps. Have a nice day.
TW
02-22-2016 07:49
02-22-2016 07:49
Hello @Josie24,
Welcome to the community!
My commute is very short, so I don't observe this phenomenon. However, one way which you may be able to avoid those steps crossed my mind.
I believe that the trackers do not track while charging, so you may be able to have it "dormant" if you get a USB battery pack and plug it in to charge when you put it in your saddlebag. I'm a bit curious, so if you try it, let us know if it works. It's is a bit of a strange workaround, I admit.
I hope this helps.
Frank | Washington, USA
Fitbit One, Ionic, Charge 2, Alta HR, Blaze, Surge, Flex, Flex 2, Zip, Ultra, Flyer, Aria, Aria 2 - Windows 10, Windows Phone
04-14-2016 05:27
04-14-2016 05:27
04-14-2016 05:48
04-14-2016 05:48
Same thing occurs when running a walk behind lawnmower. I tried loosening and tightening the strap and it doesn't help. Only way to avoid it is to use the lawnmower with one hand, but it would have to be a self propelled mower. Even then it is difficult to do with only one hand.
10-13-2016 16:07
10-13-2016 16:07
I'd be very interested in a solution. I ride my motorcycle to and from work each day...so logging my activity isn't helpful...and that, my friends, is the entire reason I purchased it.
If I take it off and put it in my bag, it still keeps on counting activity...even though there is no pulse. So this would be a problem while logging the activity of a corpse as well. And...of course since now I understand this illogicality, it lowers my trust in the steps accuracy altogether.
Question: How do you turn off a Charge 2?
11-11-2016 07:39
11-11-2016 07:39
Hi everyone, great to see you on board!
Welcome @simplicityscott, there is no way to turn off your Fitbit Charge 2, however what I recommend you is to manually log a driving activity using the time you were on the road with your motorcycle. I do it from my iOS Fitbit App by going to the exercise tab, tap in the stopwatch icon and log the activity.
You can also do it from your Fitbit.com Dashboard, click on Log, then on Activities and scroll all the way down where you'll find the option to log (picture attached).
If you have a compatible Android or iOS device, I also recommend to download an app called DriveBit while will automatically create a driving activity for you and eliminate the steps.
I'll be around if you have further questions.
What's for breakfast?Check others recipes and share yours!
12-20-2017 18:14
12-20-2017 18:14
I can't believe this is still the go-to response to motorcyclists. "Manually log the time you were on the motorcycle."
For daily commuters, this is a pretty huge pain. If I take a day trip on my bike, I'd have to remember to log each individual chunk.
PLEASE for the LOVE OF GOD add a menu option on the Fitbit to say "I'm starting a drive/ride."
12-02-2019 07:39
12-02-2019 07:39
I wish fitbit would stop telling people to log their rides manually. That is not an acceptable solution. I come back on the forums every 6 months or so to see if I can start using my watch again.
10-31-2022 00:02
10-31-2022 00:02
Hello Marlen, I tried the manual log workaround (driving), but the "fake" steps and zone mins still count in my profile. Is this solved with Drivebit app?
