04-08-2019
21:51
16:45
04-08-2019
21:51
16:45
hey guys
i have samsung galaxy A7(2018) and using fitbit charge 2 but its not support to my device now what should i do?
when i buy charge 2 it can connect easy to my phone but now its not not in the supported device list
04-09-2019 07:04
04-09-2019 07:04
@SwagatPatel A warm welcome to our Community!
I will assist you with your Charge 2 syncing with your phone. As you mentioned your phone doesn't show as compatible but that doesn’t mean it won’t work it just means that it hasn’t been tested by our team. You can try going to your phone's bluetooth settings and remove all devices listed there. Restart your phone and restart your device. After this try syncing them. Also, if you are using an Android device, check that your app has the necessary permissions (settings > apps > Fitbit > permissions) and make sure bluetooth and location services (GPS) are on. You can find additional suggestions here.
Let me know how it goes.
Best Answer04-10-2019 23:29
04-10-2019 23:29
Best Answer04-19-2019 19:31
04-19-2019 19:31
There doesnt seem to be an answer.
I have spent three days trying to get this sorted and just get told a7 is not compatable
Best Answer08-17-2019 12:56
08-17-2019 12:56
Me too, I am so frustrated. The A7 is a fab phone and fitbit will lose my custom of they don't sort this soon.
Best Answer08-17-2019 12:58
08-17-2019 12:58
I contacted customer support, they couldn't help as a7 is not compatible. Was told to buy a dongle for pc. I am so angry.
