10-22-2020
14:01
13:20
10-22-2020
14:01
13:20
Hi, my fitbit is approx 18 months old. Today the screen has vertical lines on it. I have tried to restart and reboot and it hasn’t corrected. Was anyone able to get theirs fixed? I have checked similar threads but no joy.
10-22-2020 14:29
10-22-2020 14:29
Yes ring them and explain and they send you out a new screen no problems and very few questions asked
10-22-2020 14:56
10-22-2020 14:56
Ok thank you, I will get in touch with them 👍
Best Answer10-22-2020 14:58
10-22-2020 14:58
Mine is doing the same and is only 11 months old.
Best Answer10-22-2020 15:18
10-22-2020 15:18
I had the same after a few months, they sent out a new one
Best Answer10-22-2020 15:59
10-22-2020 15:59
Mine is 11 months old to and it started with a few white vertical lines, now seems to be a faded white box with the edges of the screen visible.
Best Answer10-23-2020 08:08
10-23-2020 08:08
I got in touch by phone with Fitbit. So helpful. My fitbit is in warranty and they are sending a replacement. Delighted 😀
10-23-2020 12:51
10-23-2020 12:51
Me too, called them earlier and its getting replaced, made up 😊
10-24-2020 08:18
10-24-2020 08:18
Which phone number do I ring?
Best Answer10-24-2020 12:12
10-25-2020 16:18
10-25-2020 16:18
Thanks, replacement on it's way.
