12-29-2018
12:46
14:31
12-29-2018
12:46
14:31
Hi,
I’m new to Fitbit & I’ve tried to search what I’m having trouble with but I’ve had no luck.
I have a charge 3 but every time I move my wrist to see the time or check my steps the screen doesn’t show/light up, The only way to see this I have to double tap the screen.
I’ve checked the settings and the wake screen is on which I believe should work when this setting is on.
I wear my Fitbit on my right wrist which is also classed as my dominant hand.
Thanks
12-29-2018 15:17
12-29-2018 15:17
@Fogg14 give the left button of your Charge 3 a long press and make sure screen wake light bulb icon is set to on and not ghosted out with a line through it.
Tony | UK
Ionic, Versa 2, Charge 3 SE, Aria 2, Flyer, Note 9, Android 8.1, Windows 10
12-29-2018 15:17
12-29-2018 15:17
Tony | UK
12-30-2018 04:30
12-30-2018 04:30
@Tony.r thank you.
Best Answer12-30-2018 07:50
12-30-2018 07:50
Did this solve your issue @Fogg14? You may wish to accept it as the accepted solution if it did, that way other forum users can benefit from the answer. ![]()
01-21-2020 08:44
01-21-2020 08:44
Thanks for your solution 🙂
I had the same problem. Do you know why does it suddenly change?
Regards
Peter
