10-22-2018
11:52
18:22
10-22-2018
11:52
18:22
My Fitbit shows accurate steps on my iPhone but is not accurate on my iPad. And also won’t sync the correct steps with my weight watchers app.
10-23-2018 05:24
10-23-2018 05:24
@HenryIvy612 Welcome to the Fitbit Community! I hope you're doing well! Sorry to hear that your iPad and iPhone aren't showing the same data. Try logging out from the app, restart your iPad and then log back in. Regarding the weight watchers app try revoking the app permissions then link them again.
Let me know how it goes!
Best Answer10-23-2018 09:27
10-23-2018 09:27
Best Answer10-24-2018 13:22
10-24-2018 13:22
Thanks for the update @HenryIvy612! Sounds great that the data from your Charge 2, shows the same on your iPhone and on your iPad. If you have any other questions or comments, let me know!
I'll be around!
Best Answer03-06-2019 10:38
03-06-2019 10:38
I tried the suggestions you had with the other user and it did not work. it worked for one day. It seemed that when i had to charge my fitbit. it never worked again from the point. any
help would be great as I am so frustrated at this point
thank you
