12-26-2016
15:25
10:13
12-26-2016
15:25
10:13
***SOLVED!!!! I had to enable preview pop-ups for texts on my phone***
I had to go into settings -> application manager -> messages (the app Im using) -> notifications -> then select previews in pop-ups so that these are enabled on your phone. I found when I chose Messenger on both my phone and in the fitbit app it worked so then realised it had to be a little change somewhere in the Messages app settings and thats what it was. Let me know if you get stuck ![]()
Hi - I have a Samsung Note 4 & have enabled/selected for SMS text messages to display the sender and message on my charge 2 and also turned notifications "on" on my tracker. I recieve a notification when I get a text but it does not go on to tell me who the sender is or what the message says. When I get call notifications it tells me the name of the caller but again not with a text/SMS. Any idea why anybody please?
12-29-2016 12:50
12-29-2016 12:50
Hi ive updated my comment as I figured it out and have written what I did. Hopefully it works for you too.
Best Answer12-26-2016 18:09
12-26-2016 18:09
I'm having the same issue 😞
Best Answer12-29-2016 08:59
12-29-2016 08:59
im having the same issue
any help?
Best Answer12-29-2016 12:50
12-29-2016 12:50
12-29-2016 12:50
Best Answer12-29-2016 12:57
12-29-2016 12:57
I'm glad you have it working.
Since there is no response with an edit of your first post.. There is no way to mark your answer as a solution, I've marked your response pointing to your OP as a solution.
Best Answer12-29-2016 15:36
12-29-2016 15:36
I had to go into settings - application manager - messages (the app Im using) - notifications - then select previews in pop-ups so that these are enabled on your phone. I found when I chose Messenger on both my phone and in the fitbit app it worked so then realised it had to be a little change somewhere in the Messages app settings and thats what it was. Let me know if you get stuck
Best Answer01-20-2017 07:53
01-20-2017 07:53
This did not work for me. I went to settings, then Messages and I don't have the "preview pop up option." I have an Iphone 6 . When I first put on my Charge 2 yesterday, texts and calls were working but now they are not. Any idea what I am doing wrong?? Thank you.
Best Answer01-20-2017 08:32
01-20-2017 08:32
I have the same problem. I just got the Charge 2, 5 days ago. I got text alerts on the fit for a couple of days. Now nothing. I have IPhone 6 IOS10
Best Answer01-20-2017 14:47 - edited 01-20-2017 14:49
My partner has the same phone as both you ladies (iphone) and works in IT so il ask him to take a look at his phone and see what the set up is. I will get back to you 🙂
Best Answer01-20-2017 14:52
01-20-2017 14:52
Best Answer01-21-2017 15:26
01-21-2017 15:26
I have an iphone6. I have had the fit bit charger 2 for 3 months. I love it. 2 days ago it stop receiving notifications from Texts calls and events. I check my iPhone all the Notification planes are enabled. I didn't make any chances. I reviewed the posting and checked everything they suggested. Not sure what to do next. That's my favorite thing about the charager 2
Best Answer01-21-2017 15:50
01-21-2017 15:50
Same exact issue here! Using iPhone 7 plus. I did not make any changes, and I am no longer receiving the prompts to get my extra steps in each hour, or any text or phone call notifications. Please help, this is getting frustrating!!
Best Answer01-23-2017 20:49
01-23-2017 20:49
Best Answer01-24-2017 04:24
01-24-2017 04:24
Best Answer05-04-2017 09:28
05-04-2017 09:28
I am having the same issues as above users. i have an Iphone 6s plus and I used to get phone calls and texts on my charge 2 and I no longer get these....can you help. i don't see that you have replied to any of the iphone users on this yet....
Best Answer05-04-2017 10:31
05-04-2017 10:31
Best Answer05-04-2017 20:25
05-04-2017 20:25
Best Answer05-04-2017 21:55
05-04-2017 21:55
05-10-2017 09:12
05-10-2017 09:12
I have the fitbit surge and I can get the notification that I have a text or call, but it will not tell me from who or display the text. I have a Samsung note 5 phone. The notifications are enabled on the device, my Bluetooth is on. The pop up messages are enabled on my phone. Can someone help?
