Fitbit is less than 6months old, screen is now blank but its still loading steps when i sync, vibrates when i push the side button. Was working fine this morning, charged it for 40mins and now its not working.
OK, I just finished a chat session with Tech Support and got it back by doing a re-start:
\ While plugged to the charging cable as you normally plug it to charge, please press and hold the button on your tracker for 5 seconds. Release the button. When you see a smile icon and the tracker vibrates, the tracker restarted.\
This worked for me.
Hi @BevAP, @KBrown111, @SteveAndreski and @Bagace! Welcome to the Fitbit Family. Hope you are doing great and enjoying some healthy activities @Ajhend and @Kat-601. Sorry for the delayed response.
Thank you for all the efforts to help your Fitbit Inspire, I really appreciate the time you've taken to troubleshoot it.
Sorry about what happened with your Inspire. Have you tried restating the Inspire? How old is your Fitbit? Clean the charging contacts on the back of it. These contacts can become obstructed by microscopic dirt or debris that prevents them from making a good connection to the charger. Use a toothpick or toothbrush to clean the charging contacts; do not scrape them with anything metal because this may damage the plating and result in corrosion.
Check this article: Why isn't my Fitbit device's battery charging?
We recommend plugging your charging cable into a USB port on your computer or other low-energy device. If necessary, you can use a UL-certified USB wall charger. Don't use a USB hub or battery pack to charge, and only use the charging cable that came with your tracker. I'd like to know if you're getting the full battery sign after charging your Fitbit. Have you noticed if your charger is loose or maybe not connecting properly?
I'll be around!
Best AnswerIts done it again. Its got about 50% charged and hasnt been on charge for some time. Not impressed.
Best AnswerThis has not worked for me. Blank screen. Still vibrates and tracks but no screen. Tried holding down for 5 seconds while on charge . No luck. Tried several times. Any other tips?
