06-13-2020 02:44
06-13-2020 02:44
My fitbit inspire HR is only 3 weeks old and today will not sync with Either my ipad or iphone. I have rebooted fitbit app on both but just says Device not found. Anyone else having problems today?
06-13-2020 13:44
06-13-2020 13:44
Thank you so much, I Have done as you said and went through Bluetooth to forget device and fingers crossed my Fitbit HR has just synced. Thanks again
06-13-2020 06:19
06-13-2020 06:19
Mine also will not sync. I have tried to uninstall the app, restart the fitbit and iPhone. It cannot find Bluetooth. My husband tried to install the Inspire on his phone and all went smoothly. We both have an iPhone. Not sure why it won't sync. The fitbit is less than 2 weeks old.
06-13-2020 07:56
06-13-2020 07:56
I just went to the iPhone settings and said to FORGET the device for the fitbit. Then went through the installation and it worked!
06-13-2020 10:46
06-13-2020 10:46
It did sync at 5.00 pm on phone but not on ipad, still says device not found. But it is not syncing again now on both phone and ipad. Really annoying I’ve been really active today and now no stats to show for it!
I too have deleted app on both and reinstalled but no joy!
06-13-2020 10:49
06-13-2020 10:49
Did you lose your past data when you did this?
06-13-2020 10:52
06-13-2020 10:52
06-13-2020 13:44
06-13-2020 13:44
06-13-2020 17:16
06-13-2020 17:16
07-04-2020 15:25
07-04-2020 15:25
I did this and it worked but I have had to do it three times already today. Just got another message to go the Bluetooth and forget inspire.
07-26-2020 18:40
07-26-2020 18:40
I tried all these steps , but it’s not working
07-26-2020 20:26
07-26-2020 20:26
i have an iphone 11 pro max and every few days my fitbit inspire HR stops synching. i either have to delete the fitbit app from my iphone and reinstall it and then go through the process of reconnecting the fitbit which takes ages and then synch or i have to forget the fitbit in the iphone app and reconnect and then synch. i believe that the fitbit app is defective and has not been properly tested with all iphone models. the fitbit support people keep trying to pass the buck and blame everything except their app and mostly try to refer me to Apple when their software is deficient.
07-30-2020 03:44
07-30-2020 03:44
I had the same issue for weeks. I had to constantly go to blue tooth and forget the device and add it again in order for it to sync and provide notifications. That has since resolved and now it won’t recognize any exercise.
08-06-2020 09:58
08-06-2020 09:58
Me too ! Has not synced since 8/3.
i wear it ti track sleep and HR. This has been going on for as long as I’ve had it. Want to upgrade but not if it will be the same problems.
so frustrating.
