06-01-2020
21:07
10:24
AlvaroFitbit
06-01-2020
21:07
10:24
AlvaroFitbit
Last time I charged Inspire the time changed to 7-1/2 hours earlier. I tried to follow instructions on FitBit site but did not work.
It syncs occasionally but I cannot manually sync. Can it be set up with Bluetooth for All-Day sync? Tells me to setup but not how?
06-04-2020
11:27
06:59
06-04-2020
11:27
06:59
@Haefeli Thanks for being part of our Community!
Let me help you with your Inspire not updating the time nor syncing. You can try the following:
The restart should also help keeping the time. You can change it again by following these instructions.
Let me know how it goes.
Best Answer06-04-2020 17:33
06-04-2020 17:33
Best Answer06-21-2020 11:43
06-21-2020 11:43
@Haefeli thank you for your reply.
You can try only removing the Inspire from the bluetooth settings and see if this helps resolve the issue.
Keep me posted.
