10-29-2019 09:23
10-29-2019 09:23
This has happened a couple of times now. Where the face goes totally blank and you can push the button and nothing happens. If you hold it it vibrates but doesn't show anything. Anyone else having this issue. This morning it went blank for over an hour and is back on now. I just don't want to wait too long if it needs to be returned
Best Answer10-29-2019 10:05
10-29-2019 10:05
I have an inspire , and I'm in the same situation as You, but I don't know whyit happened
Best Answer10-29-2019 10:17
10-29-2019 10:17
I just don't want to leave it too long if I have to return under warranty.
Best Answer10-30-2019 08:43
10-30-2019 08:43
Mine went blank about a week ago. I changed the clock face and that worked for me.
Best Answer10-30-2019 09:32
10-30-2019 09:32
Best Answer10-30-2019 13:22
10-30-2019 13:22
I have an Inspire that is only about 4 months old. It was working well until yesterday. The display would not move when I swiped it and then it went blank. It stopped syncing as well. It does vibrate when I connect it the charger. Nothing happens though. I push the button and the display stays blank. Please replace it or let me know what to do to get it working again.
Best Answer10-30-2019 13:58
10-30-2019 13:58
Best Answer10-30-2019 15:16
10-30-2019 15:16
You can change the clock face through the app. Here's how it works on Android...
*Tap the icon that takes you to your account.
*Tap your device.
*Tap the Clock Faces icon and select All Clocks.
*Tap your preferred clock face and tap Select.
*The app will then connect to your Fitbit and install the face.
Best Answer10-30-2019 16:51
10-30-2019 16:51
Best Answer10-31-2019 05:36
10-31-2019 05:36
