12-13-2019 21:20
12-13-2019 21:20
Why is it that in order to check my phone calls or texts I always have to login to Fitbit first?
12-13-2019 23:36
12-13-2019 23:36
Hi @Debexercise What phone are you using?
Helen | Western Australia
12-14-2019 06:06
12-14-2019 06:06
12-14-2019 16:17
12-14-2019 16:17
OK that is really odd. It is the same phone that I use and I never have to log in to see my notifications. Besides which is IS a supported phone so should work. Firstly Id suggest you check all your phones settings in the phones settings app (not the fitbit app).
Here are some of mine for you to check. The first is the settings app, under apps and select Fitbit. The second is under Lock Screen.
12-14-2019 16:18
12-14-2019 16:18
Here's the second one
12-15-2019 05:49
12-15-2019 05:49
12-15-2019 07:09
12-15-2019 07:09
Glad you got it sorted!
