06-01-2019 14:42
06-01-2019 14:42
Hey,
I saw a post (link below) that said that you can change the date format from MM/DD to the international format DD/MM.
I have tried what the post said but it doesn't work for me for some reason. Please see my screenshot for the settings I have set in the fitbit.com dashboard.
Is this just a bug or am I missing something?
Thanks for your help.
Best Answer11-01-2020 22:23
11-01-2020 22:23
This was really helpful, thanks 😁😁
11-18-2020 05:18
11-18-2020 05:18
Hi
I am in Australia and we use DD/MM not MM/DD
All of my settings are correct
Language and TImezone, but my watch still displays MM/DD
Am I missing something ?
Best Answer11-18-2020 06:37
11-18-2020 06:37
Hi,
I don't think you can get it to display the date as DD/MM. It will only use the american format.
The best you can get is for it to show the long month format (e.g. Nov 18).
I thought I had posted the instructions for doing this, but I can no longer find it. If I recall correctly it involves using the app on your phone and selecting a different clock face.
I can't check this as I decided to return the device and get my drinking vouchers returned.
Best Answer11-19-2020 00:08
11-19-2020 00:08
Thanks , can anyone confirm this for me? Seems like a weird restriction
11-19-2020 00:36
11-19-2020 00:36
07-12-2021 07:38
07-12-2021 07:38
Any date format and time etc can be adjusted by editing the clock face settings
07-12-2021 17:49
07-12-2021 17:49
Welcome to the Fitbit Community, @Mesm8914.
Thank you for joining the thread and sharing your suggestion. I appreciate your time and efforts to help other users. Let me invite you to visit our Health & Wellness board where you can share your experiences, make new friends and create your own topics.
Keep on visiting the forums!
Best Answer07-13-2021 00:00 - last edited on 07-14-2021 16:12 by LiliyaFitbit
True - but which format will show the date in anything other that US format..As Donald J Trump said "Did you know there are over 181 countries?"
Moderator edit: format
07-13-2021 04:20 - last edited on 07-14-2021 16:11 by LiliyaFitbit
They have serval. Look at clock face that is called 101 options
Best Answer07-13-2021 05:07
07-13-2021 05:07
No such clock face available. ONLY date format is US. There are other countries, you know.
07-13-2021 06:17 - last edited on 07-14-2021 16:11 by LiliyaFitbit
When on clock menu and looking at a clocks settings, it's on that bit where
you edit it
07:02
09:36
SilviaFitbit
07-13-2021
07:02
09:36
SilviaFitbit
Here is my post from 1st March 2020 (or possibility 3rd of January 2020 - it depends on which country you are in).
For those of you still hacked off about the date format, you could try changing the clock to "Just Time".
This is still US format but shows as "Jan 03", which at least has the decency to remind you it is in the wrong format.
Moderator Edit: Formatting
07-13-2021 07:53
07-13-2021 07:53
I must say that this matter really turned me off Fitbits right from the very start but I did find a way to set the time and date as near as possible to an Australian acceptable format. You'll find your Fitbit useful for maybe several months but after a while you generate an exercise routine (and a healthy diet) that comes naturally and you'll end up doing it without the device. Honestly, it helps you at the start but when you start becoming fitter by default activity (walking and a step machine is my go-to), when you remember to put the Fitbit on, it's battery is flat so you just do what you have to do anyway. Yes, it's motivational stuff about how great you've been to do 10,000 steps in a day is good at the beginning, but you'll find it's also not something you want to be reminded about (wearing out knees for example) as you do keep going. Sometimes it good to do things in moderation which also gets results, maybe safer results. You won't need to be looking for a date or time as much because honestly, you'll have your Iphone, or the like, in your pocket when not at home and that too can do a whole range of step recordings and calorie counting with a much better interface and visual presentation.
Best Answer07-13-2021 08:36
07-13-2021 08:36
Right from the start, because I don't want to have to put up with US date format, I chose a clock face without the date. I don't think this is satisfactory.
I live in Corsica, at the moment in Italy, and it is not possible to have European date format.
07-13-2021 08:57 - last edited on 07-14-2021 16:12 by LiliyaFitbit
It isn't in the app settings or the basic settings but from different clock
face settings directly. So where one would change the colour of the digits,
change the widgets or the face layout is where this would be possible. This
is only true for certain clock faces and you have to look at each one
individually to see
Best Answer07-13-2021 11:06
07-13-2021 11:06
Change the colour? Thought the Inspire HR was only black and white. Never seen another other colours on mine.
