03-10-2020
09:51
15:26
RicardoFitbit
03-10-2020
09:51
15:26
RicardoFitbit
so far feeling disappointed by the Inspire HR... my previous Alta HR gave me such joy especially being able to change the clock face to horizontal or vertical. The button on the side seems to do nothing. all my tapping keeps showing me the clock and stats as tiny underneath. also now I'm stuck with USA date formatting when I live in Ireland, this will only get me more peeved the longer I have to look at it. is there any way that I can get the Inspire HR to behave more like the Alta HR
Best Answer03-11-2020 19:10
03-11-2020 19:10
Oops, I totally read that wrong. Sorry. I even remember thinking “weird, I never thought about there being different time formats around the world - he must mean 24hr format”. Someone has already added the DD/MM format to the Feature Suggestion board and it has several votes - you should vote and add a comment here. While not really a solid fix, someone within that feature post suggested the “just time” clock face because the “MAR 12” format is a little less annoying.
Best Answer03-10-2020 22:27
03-10-2020 22:27
@DBBaldwin You can change to 24 hour clock format by going to your Fitbit account online (not the app) and following instructions here . Agree that the side button doesn’t do much - you can hold it in to get some access to settings. You get to most of the functions by swiping up or down from the clock screen.
Best Answer03-11-2020 15:59
03-11-2020 15:59
thanks for trying but that was not my issue... my issue has to do with Date formatting. I live in Ireland where we have dd/mm but all the date clock faces I'm presented with in the Inspire HR are in mm/dd.
03-11-2020 19:10
03-11-2020 19:10
Best Answer03-12-2020 09:14
03-12-2020 09:14
it was one of the options i considered trying but it's still quite annoying considering this was a non-issue with the last 2 Charge-HR's and Alta HR, all of which have come across my "desk" for using and sorting out. thanks for the link have added my tuppence worth & vote for this feature to be included.
