10-05-2022
05:50
21:04
10-05-2022
05:50
21:04
I see this has been reported umpteen times, and I can't see a cause or a fix anywhere, but perhaps someone can help, even if not Fitbit themselves.
- it is worn correctly on my wrist (it worked fine for 2 months)
- the battery is not run down
- sleep tracking is automatic
- my sleep patterns have not changed and last more than 3 hours
- in addition, I have done a full reset of the Inspire 2
None of this makes any difference. Is there actually a solution to this, or do I just write it off?
10-05-2022 09:53
10-05-2022 09:53
Heart rate tracking is necessary for sleep tracking, so fixing that might fix the sleep tracking.
First, make sure your Fitbit is set to On Wrist. To do this, access the secret settings by holding both side buttons for about 2 seconds. You should see Water Lock pop up, scroll down to the bottom of this list and make sure it says On Wrist.If it says On Clip, tap that and change it to On Wrist.
If that doesn't fix your heart rate tracking, there is another option in the regular settings. Briefly tap both side buttons until the screen turns on and shows your main watch face (time, etc). Scroll up until you see the gear icon with Settings under it. Tap that and the first option should be Dim Screen, the second should be Phone GPS and the third should be Heart Rate. Make sure Heart Rate is set to On.
10-05-2022 09:45
10-05-2022 09:45
Does it still measure your heart rate?
Best Answer10-05-2022 09:51
10-05-2022 09:51
10-05-2022 09:53
10-05-2022 09:53
10-05-2022 09:59
10-05-2022 09:59
Thanks - the first part was all OK - the second wasn't. For some reason my heart rate tracker had switched off, don't ask me how. I have switched it back on and will see if it goes back to normal. Thanks for the suggestion!
10-05-2022 13:05
10-05-2022 13:05
You're welcome! Hope it fixes your issue!
Best Answer10-06-2022 01:07
10-06-2022 01:07
That worked! Simple really. I never saw that check in the other responses. Just the flannel about why it might not record properly...
Thanks again.
01-03-2023 00:27
01-03-2023 00:27
Thanks for this. I didn't realize there was a setting for sleep and wrist vs clip.
Best Answer01-04-2023 09:15
01-04-2023 09:15
new user and must have accidentally changed the setting yesterday morning, Thanks for the advice!
Best Answer04-19-2023 16:31
04-19-2023 16:31
Enable on Wrist? Is light . I can not not change to dark Underneath it what is dark : all feature are available. Does it mean that the wrist is enabled . This is a new inspire 2 and the sleep data is not working .finding inspire 2 difficult. To move around.
Best Answer08-01-2023 08:49
08-01-2023 08:49
Tried both options and my sleep still isn't tracking. It stopped the day my premium membership was done. My HR is tracking.. just not my sleep
Best Answer08-01-2023 11:50 - edited 08-01-2023 11:50
Good to see you around the community @Born2write.
Thanks for letting us know about the inconvenience with your Inspire 2.
In addition to the suggestions provided above, please keep in mind that there are some factors that may prevent your tracker from recording your sleep. Please make sure of the following:
If you haven't done so already, please try to complete a restart.
In addition, please wear your device on your non-dominant hand and monitor it for the next few days. In the meantime, for the nights that don't have sleep data, you can manually log your sleep by going to the Fitbit app, tapping on the "+" icon next to the sleep tile > Add Sleep Log and entering your details.
12:40
08:08
EstuardoFitbit
08-01-2023
12:40
08:08
EstuardoFitbit
Sadly I have tried all of that. Spoke with customer service today and hopefully it will work and start tracking sleep again tonight.. I'm not too optimistic but I guess there's hope
As an update, what we tried yesterday seemed to work. Try changing your sleep setting on your Fitbit dashboard on your computer. Change from sensitive to normal... then re-boot your Fitbit and "add new device" to your app... It worked and it tracked my sleep last night. Hopefully it keeps tracking. 🤞
Moderator Edit: Merged replies
