I got a typical low battery notification on my phone so I held the button to check what percentage it was on but it'd just vibrate and stay on the same screen. I cant use any of the functions by tapping on the screen or swiping for a few minutes then after awhile I can tap the screen to scroll through the quick stats but I can't swipe up or down and if I try to hold the button it will freeze the screen again.
I tried to restart it (plug it in and hold the button for 5 seconds) but nothing would happen other than it vibrate and then the screen would timeout.. Do I just have to wait till it dies?
Best AnswerThis actually worked! Thanks for the tip
Best AnswerI noticed the same problem with mine this morning. I found your tip and tried it myself and it worked for me too. Many thanks!
Best AnswerWas skeptical about this tip, but IT WORKS!!! Plus got to find out there are some really cool clock options. 🙂
Best AnswerGreat tip! Worked for me, too! Many thanks 😊
Best Answermy screen is frozen how do i fix it i can not scroll up or down
Best AnswerJust called customer care for same problem, they told me to plug in and hold button for 5 seconds to restart, it actually takes a wee bit longer but it worked 👍 also seen on here about changing clock face does the trick too!
Thankyou so much for this tip. I was in such a shock when it was frozen. Thanks again. If anyone has this problem TRY IT.
This helped for me as I have a fitbit inspire hr and it does not have a square clock face, so changing the clock face was not an option. Glad its working again with restarting by plugging in and holding for 5 seconds. Thanks!
