11-23-2020 23:52
11-23-2020 23:52
So I just found out about Fitbit studio and I got really exited because I thought I could make my own clock faces. Then a couple of days later I try it then I think about how I would get it on my Inspire HR then I see it’s only on select devices and now I can’t really make a clock face
I think that the Fitbits (all of them) should get an OS update that allows them to be compatible with SDK or for the Fitbits that aren’t compatible with SDK should get a little designer thing in the app when you press all clock faces button there’s like a little plus where you can click on it and then it pulls up a little editor that has like the date time steps and all that good stuff
to sum it up I really wish that you would add A feature that allows us the community to make a watch face
03:35
11:12
11-30-2020
03:35
11:12
@Oofram It's great to see that you've visited the Fitbit Community!
Thank you for your idea to design your own clock faces for your Fitbit Inspire HR. This option is only available for smartwatches as they have a more robust/powerful OS due to different components in them. I don't know the technical limitations but if you wish you can share your idea in our Feature Suggestions board. Search for the idea first to see if one already exists so you can add your vote. The more votes an idea gets the more likely the developers will try to implement it.
Let me know how it goes.
