01-06-2020
17:41
07:49
AlvaroFitbit
01-06-2020
17:41
07:49
AlvaroFitbit
I noticed about 5 this afternoon that I only had 877 steps when I know that I had over 3200 (still using my zip). Is this a bug or do I have a bad device?
Best Answer01-07-2020 08:33
01-07-2020 08:33
@aliciaef Welcome! It's nice to have you on board!
Let me help you with your Inspire HR resetting its steps. Has this happened before? Does the Zip shows a different amount or did you started using it after the Inspire HR showed the reset steps? How often do you sync your trackers?Is it showing the correct time? Did you log any activities on your account? I suggest you restart your device and monitor its behavior and make sure it is syncing periodically.
Let me know how it goes.
